Easton made or Wolf Ridge owners, can I get a few dimensions?
Discussion in 'Chainsaws and Power Equipment' started by Casper, Aug 21, 2020.
  1. Casper
    Casper
    Found a couple 6"x6"x¼" web and ⅜" thick top and bottom plate, I-Beam that are 6' long.
    Also, have several (there are more than what's in the pic) steel plates that are 18"x18" and a mix of ¼, ½ or ¾" thick.
    I want to make a replacement "push-through" beam for my 22ton White (MTD) horizontal/vertical splitter. I'm curious of the thickness of the single wedge, and wings that would make up a 4 way wedge. Also, if I could get pics of how they "box in" the pocket for the drop-in, that would be great too.
    From what I can see, having the cutting edges angle forward (toward the push plate) reduces the stress on the components and allows for a lower Tonnage cylinder.
    The goal is to pull the current cylinder and wedge carriage. Remove the factory beam and install the one that I fab. This would allow me to switch back to factory configuration if my brainiac idea doesn't work. I am putting trays on the side and a fold up table/grizzly bars on the output end. I want to be able to split into my PUG, tractor bucket, dump trailer or truck without bending over.
    Any thoughts or tips are appreciated!
    Thanks.
    BuckthornBonnie likes this.
  2. isaaccarlson
    isaaccarlson
    Colfax, WI
    I am using a 4x10x17 i beam. some would call it wimpy or laugh at it, but it works. It was free when a friend moved. My splitter makes 21 tons and the beam has been holding up fine. Lots of wood split every year.
    Casper and SKEETER McCLUSKEY like this.
