Dump trailer! need advise
Discussion in 'Chainsaws and Power Equipment' started by swags, May 2, 2015.
  1. swags
    swags Moderator
    Ok who has a dump trailer? I really need to get one for work. I made the jump into flipping houses full time this year and need to buy a trailer. I've rented one a few times, and borrowed but need to get my own. Uses would be everything from hauling shingles, gravel, dirt, wood, equipment ect. Looking for one that's 7x14 and at least a 12k trailer so I can haul a bobcat.
    What manufactures are good, bad? Anything to look for? Prices?
    clemsonfor, Eric VW, wildwest and 2 others like this.
  2. papadave
    Can't help re: the trailer Sean, but good luck and have fun with your new endeavor. :ithappened:
    How's the market nowadays?
    Flip 'em quick!:)
    clemsonfor, wildwest and Chvymn99 like this.
  3. TurboDiesel
    Bri-Mar makes some nice dump trailers. I'd start there.
    Not sure if you can load a bobcat in a dump trailer . They are usually pretty heavy.
  4. TurboDiesel
    This must be a pretty heavy one. Most have one small lift cylinder in the center
  5. tuneighty
    tuneighty
    South Central PA
  6. jetjr
    jetjr
    Pa/Md line
    Have you thought of looking at one of the hook type trucks that you can get different beds for. I know way more expensive, but maybe a good investment.
    clemsonfor, Eric VW and wildwest like this.
  7. millermodsaws
    millermodsaws
    I use these quite often and am looking for a 14' gooseneck one as well. Here's the few little things I know. IMO the ones that the bed floor rails run side ways are much more sturdy. I've seen the floors warp in the others. And one with the scissor lift works better than the ones with dual hydraulic cylinders. Again all my opinion but the one I get will have these to options. Lol. Good luck with your hunt.
    Barcroftb, HDRock, Eric VW and 3 others like this.
  8. fox9988
    fox9988
    NW Arkansas 72717
    I'd suggest a gooseneck. If your pulling heavy loads, they pull amazingly better than a bumper pull. Its one of those things you kind of need to experience to fully appreciate/believe. They are extremely stable, don't whip the truck around. I've put a few thousand miles on mine behind my old 3/4 ton Cummins, with the trailer grossing 15K. Hauled a load of stone, trailer grossed 19K, 26K total on the scales, no problem.
  9. Chvymn99
    Good Luck on your new endeavor swags .... Sounds interesting...
    Horkn, Eric VW and wildwest like this.
  10. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Also might want to be confirm that the dump trailer is properly reinforced in the dump bottom to handle being driven on.
  11. swags
    swags Moderator
    You can get them to load equipment in as well. Many of them have doors that double as ramps for loading. Nice thing about being able to haul a bobcat is if I need the bobcat I can pull it to the job, and then use the trailer to haul away dirt or bring in gravel. Saves having to haul two trailers/trucks to a job.
  12. JustWood
    JustWood Guest
    CAM Superline makes a good trailer.
    My IS heats my home and Eric VW like this.
  13. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    That's what I was gonna say. My buddy has a bwise and loves it. I've pulled/used it and the quality is fantastic. I have a sur-trac that is high quality as well although it's not a dump. I used a cam dump and it wasn't on par with the sur-trac or bwise for overall quality. Never pulled or used a bri-mar..
  14. Oliver1655
    Oliver1655
    Central Missouri
    Thoughts for a dump trailer:
    - Split - 1/2 !width doors for the back. Much better than a full width door.
    - Largest dual purpose, (deep cycle/starting) battery you can fit in the battery box. Electric hydraulic pumps will place a heavy draw on the battery.
    - Solar battery charger to help keep your battery charged.
    - Minimum of a 10 ply/load range "E" tires. I use 14 ply/"G" on my trailers.
    - A heavier duty, (10k lb each), 2 axle trailer will turn easier & have less stress on the tires & axles than a 3 axle trailer.
    - A goose neck will turn sharper but needs a wider turn radius to keep from cutting off the inside corner.
    - A bumper hitch will allow you to carry your tools/supplies in the bed of the truck & to have a cover over the bed to secure them & keep them dry.
    - Electric brakes on both axles.
    If you were using the trailer mainly for hauling I would go for a goose neck. However, since it sounds like you will be doing a lot of remodeling & need to haul tools/supplies, I would recommend the bumper hitch.
    Note: Use a 20 - 30k rated 2-5/16" ball with a solid 2" receiver hitch. Cheap insurance.
    Hope you new endeavor goes well!
  15. swags
    swags Moderator
    I know for sure I will get a bumper pull not a gooseneck. I would like a goose neck but don't have the truck set up for it and my brother will use it a lot and he doesn't have a gooseneck either. And most tims I will need the bed of the truck for tools, saws ect.
    I know I want a dual hydraulic trailer, and looking into brands.
    Locally a lot of guys recommend Appalachian trailers.
  16. lukem
    If you are going bumper pull get some airbags for your truck. You don't need an on board compressor...just bags and fill lines. A skidsteer in a bumper pull dump trailer is going to send the front end of your truck to the moon.
    Barcroftb, Drvn4wood and MasterMech like this.
  17. swags
    swags Moderator
    I put an add a leaf on the truck, 1 in the back and a few in the front, that should help.
    Also I won't haul the bobcat on there much, but I don't think it should be much worse then the flatbed I have now.
  18. 94BULLITT
    94BULLITT
    Frederick County, VA
    Suretrac makes a very nice dump trailer. The frame is made out of tube, not channel like most. They are acid washed and powder coated. All of the seams have seam sealer to prevent rust. They have LED lights. The suretracs have the key way side giving them a very strong side.
    http://harrisburg.craigslist.org/ctd/4987008995.html
    Brimar makes some nice trailers but the like turbodiesel posted is an economy model. You can push on the sides with your hand and see them flex.
    PJ's are nice, they are actually overbuilt. The bad thing about them is the finish.
    Brian Wise owns Brimar now too. The Bwise trailers are very pricey for what you get.
  19. TurboDiesel
    10 % of the trailer weight should be your tongue weight. A 10,000# trailer should give you 1000# tongue weight. If 1000# sends your lights to the moon you need more truck or a weight distribution hitch.
    Horkn, Oliver1655 and swags like this.
  20. TurboDiesel
    I agree. You usually get what you pay for.
