Dumb question…fire before chimney sweep?
Discussion in 'The Wood Pile' started by grandgourmand, Oct 20, 2023.
  1. grandgourmand
    grandgourmand
    Ontario
    At the farm this weekend and it’s pretty nippy outside. I’d like to get a fire going today and tomorrow…but having the chimney sweep on Monday. Is that an issue?
  2. RCBS
    RCBS
    Over here
    Being aware that you need a sweep is an indicator that you will likely burn responsibly. The sweep does allow for making sure that there are no obstructions (nests, dead coon or a sheet of creosote that has fallen from the side walls but no to the fireplace), which is probably a greater issue than the creosote on your chiney walls.
    But yeah...try to get after it before weeks or months long fires become the norm.
  3. stuckinthemuck
    stuckinthemuck
    Go for it. Start a small fire with paper to verify no obstructions. Then let her rip!!
  4. brenndatomu
    I'd probably build a very small fire with some very small kinlin (something that will burn hot n fast) just to warm the flue and make sure that the flue is not plugged up...this before letting 'er rip with a big fire...that way if something is not right, its easy to snuff the fire and not have a bunch of smoke rolling out of the stove for the next hour
  5. Erik B
    Erik B
    Western Wisconsin
    I had morning fires up until 2 days before getting the chimney swept. As long as it was cold, he had no problems.
  6. brenndatomu
    Maybe I misunderstood the question?
    Is it ok to get things hot before he comes?
    I'd say as long as your last fire is 24 hrs or so before the cleaning, it should be fine.
  7. Backwoods Savage
    I've never let stove or chimney get cold before cleaning the chimney. Just let the wood burn down then clean.
  8. billb3
    I pretty much have to remove a pipe to clean mine so fire needs to be totally out, as in no hot coals, although I suppose I could cap the stove for a bit. Or remove the coals could be a plan B. or just make believe they're not there could be plan C. Temporarily.
    Course, it's Monday so it's probably too late for options. :)
    grandgourmand likes this.
  9. Erik B
    Erik B
    Western Wisconsin
    Don't forget, there is always July or August:whistle::zip:
  10. grandgourmand
    grandgourmand
    Ontario
    Ya I know…I contacted the guy late August. He was pretty booked…also semi-retired. Maybe I should learn before he fully retires!
    Erik B and brenndatomu like this.
