Drolet wood furnace
Discussion in 'Modern EPA Stoves and Fireplaces' started by Shawn Lettre, Dec 27, 2019.
  1. Shawn Lettre
    Shawn Lettre
    Berlin NH
    I am thinking about getting the heat max for next year. The owner's manual said it recommends a 6 inch liner or flue opening. Can I choke it down to a 5 inch stainless steel liner?
    Horkn, yooperdave and wildwest like this.
  2. stuckinthemuck
    stuckinthemuck
    A 5” diameter pipe has 30% less cross sectional area than a 6” diameter pipe. That seems like a big reduction.
    Horkn, yooperdave, Ohio and 1 other person like this.
  3. yooperdave
    You can always call drolet customer support and ask. But I'm sure we both know the response to be heard.
    Why would you want to reduce it to 5" anyway?
  4. brenndatomu
    Did you post this question on another site?
    If so, you already have my answer...probably not...you could try it, but be prepared to change to a 6" then if it doesn't work.
    That's a big reduction for any appliance that is designed to run on a 6"...it might operate the stove OK, but the issue will probably be smoke rollout when loading...
    Horkn, T.Jeff Veal and wildwest like this.
  5. Highbeam
    Highbeam
    There is good reason to crosspost. Some good folks refuse to use both forums.
  6. fox9988
    fox9988
    NW Arkansas 72717
    Guilty.
  7. Shawn Lettre
    Shawn Lettre
    Berlin NH
    That's what I have for a liner now.
    yooperdave and Horkn like this.
  8. stuckinthemuck
    stuckinthemuck
    How long Is the liner?
  9. Shawn Lettre
    Shawn Lettre
    Berlin NH
    My liner is 32 ft long
