Downdraft problem, looking for suggestions
Discussion in 'The Wood Pile' started by JDU, Jan 21, 2025 at 2:54 PM.
  1. JDU
    JDU
    Perry County, PA
    Have a small potbellied wood stove in the basement that I rarely use, rely on insert in living room for main heat source.
    Has a 6” stovepipe into a 6” thimble that goes into a block and lined masonry chimney. See attached photos. Problem is, on real cold days like this morning when it was single digits, there is such a terrible downdraft I cannot even light a fire as it blows all the smoke out the stove seams and smokes up the basement.
    If it is not super cold I put a propane torch in the stove directed up the pipe for 5 minutes, and it preheats chimney enough to get a proper draft and fire started. Lower temps when I really want it, no go even doing that. I thought of trying to heat the metal pipe with torch from the outside and then up inside?
    I have used all kinds of wood stoves with all kinds of chimneys and have never seen anything like this. Has me pretty frustrated. Anybody have any suggestions?
    Thanks in advance.
  2. RCBS
    RCBS
    Over here
    I don't. That should pull. Pretty well really.
    Only thing I got is to get it lit before the temps get real low. My woodfurnace almost always pulls draft with an almost identical chimney as yours. Occasionally I will need to fire off a couple pages of newspaper or something to reverse the draft. Honestly beleive it has something to do with barometric pressure. I think I've seen one way draft valves but know nothing about them. Thankful I have never had this fight.
    Just a thought...do you have an outdraft somewhere in the basement maybe? That air is encouraged to travel somewhere. Is your other stove's draft pulling hard enough to affect? (spitballs)
  3. JDU
    JDU
    Perry County, PA
    No outdraft in basement, and don't think woodstove upstairs is issue, as it is opposite end of house and door to basement is pretty tight. But good thinking.
  4. RCBS
    RCBS
    Over here
    One way to eliminate the other stove sucking the air would be to try to light the basement unit when the other is cold. Air has to be going somewhere is my thinking.
  5. John D
    John D
    Syracuse ny
    Only thing I can think
    You said the basement door seals tight do you have enough air entering the basement to replace what the stove is exhausting
  6. lukem
    This is probably a really stupid suggestion, but are you sure you have that damper open all the way on a cold start?
  7. Va Homesteader
    Va Homesteader
    Central Va
    close the upstairs door leading to the basement and open a basement window or door to the outdoors. this will correct it. once lit you can close basement door or window and open upstairs door.
  8. JDU
    JDU
    Perry County, PA
    Yes.
  9. imwiley1
    imwiley1
    Wisconsin
    You could try closing the damper, that should stop or slow the downdraft, put the torch in the stove for a few minutes to get things warming up, then open the damper after a few minutes and see if it starts up drafting.
  10. brenndatomu
    Try a hair dryer instead of a torch...heat and positive air flow/pressure up the chimney
    Any recent changes to the house?
    Insulation, air sealing, windows, change out an appliance?
    Something running that isn't normally... exhaust fan(s) clothes dryer, central vac system?
    Cash Larue, RGrant, Brad M and 11 others like this.
  11. JDU
    JDU
    Perry County, PA
    No changes, hair dryer excellent idea.
  12. Skier76
    Skier76
    CT and SoVT
    Our wood stove is on the finished lower level of our weekend house. It’s a 6” outlet from the stove that has two 90 degree bends before going to an 8” thimble to an exterior 8” metal chimney that doesn’t clear the roof peak. So yeah, not ideal for drafting.
    That being said, I’ve had good luck with a propane torch between the baffle and the top of the stove. I also open a window and a downstairs door. When we get up there, the house is pretty cool and the stove is fighting for air against the direct vent wall heater and power vent hot water heater. Opening the window and door help significantly.
  13. wildwest
    Wyoming high plains
    I have a similar chimney, cement block with liner, on exterior wall. brenndatomu suggested the hair dryer to me several years ago and it works great for us. Sometimes my husband has to run it longer than other times. He was using my folding travel hair dryer that I did not like or use eventually burned up. So then I bought a new version of my favorite hair drier from 1994 and he uses the old one now :D
  14. brenndatomu
    Is the basement pretty cold?
    Do the basement stairs have a door that separates the two floors?
    It so, any change with door open vs closed?
    Oops, I guess that was asked already
  15. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Interesting to read this today. My stove is a basement install, straight up single wall for 36” then 45 to a wall thimble and out, 90 T and straight up class A exterior. I have negative pressure so use a hair dryer to pre-heat the flu until it’s warm to the touch and light it up. Never a problem once I figured that out as I’ve smoked my house up a few times over the years. I switched jobs last year and just haven’t css enough and am low on wood and the wife loves the fire so I turned in my man card and bought wood, of course advertised as seasoned which I knew better. So I am keeping the fire hotter than usual and adding wood much sooner than when i had 3-4 year css wood.
    anyways, yesterday morning I come down and the pipe was cold, yet visible hot coals in the stove. I slid the air damper all the way open and waited a bit. Before I opened the door, I checked a nearby CO meter and it showed 50ppm so I knew I needed to get a hot fire going quickly. I had a box of very small split super dry oak, some super cedars and this newer wood but ended up setting every smoke alarm off in the house and had to vent my own house to rid the smoke ‍♂️‍♂️‍♂️. It was -11f over night with a full stove, including a couple large but 4 year css oak so I am at a loss of why I lost draft.
    I will clean the chimney this weekend hopefully as I suspect it’s got some buildup already from this non-ready wood.
  16. brenndatomu
    Screen on the cap plugged? Not hard to do when it's this cold, especially with wet wood...can ice over too.
  17. jtstromsburg
    jtstromsburg
    Didn’t seem to be, but I took my taller extension ladder over to the camp I work at. I did beat on it with the tall stick so maybe that cleared it up As after a few minutes, I finally saw smoke coming out the chimney and got things going the right direction.
  18. SD Steve
    SD Steve
    South Dakota
    Yep, my house has a terrible down draft as well. I usually have to make sure my the dryer is off , 1st floor door is cracked open, propane furnace off. Etc.
    It has taken as long as 5-10 minutes before it will correct itself
  19. wildwest
    Wyoming high plains
    :rofl: :lol: I had two different vehicles like that! If using radio, A/C and horn etc. it could only be done in certain way or fuses would pop.
  20. SD Steve
    SD Steve
    South Dakota
    That's neat that you're in Stromsburg NE. My sons and I drive right through there everytime we drive from SD to TX on 81.
    "The Swede Capitol of the world",
    I think that's what the signs say
