hello anyone got this kit? Costco Wholesale (the kit seem to have different brand name when googling it) I'm interested to know all dimensions of all pieces. I want to replace my current dual pipe with this mostly for the double 45 elbows from the kit also, I never used telescoping pipe, if I have to use it, how does it work with temperature probe? I'm hoping that I can make it work without using that one. I wish, I guess I will need to get it to try it for; (at least with costco I can return it without problem) 28 inch up, 45 elbow, 12 inch diagonal, 45 elbow, 6 inch horizontal the unknown are the elbows, no idea the dimension of these
Made by Security Chimneys, called Secure Black DL - [email protected] - They are out of Canada, but may have a US Dealers
Flue probes work fine with double wall stove pipe. Just drill straight through outer/inner wall, and stick probe in. Use a smaller drill bit for the first hole, and then use the required size through the pilot hole you've drilled. Even if the probe isn't a 100 percent friction fit, after 2-3 fires, ash/crud or whatever happens to line your stove pipe will have it sealed.
following this http://www.securitychimneys.com/wp-..._Catalog_EDLSW_Secure-Black_05-10-17_V2_W.pdf if the kit i'm looking at costco follow the same pattern 2 45 elbows raise around 12 inch so 28 up + 12 (2x elbows) = 40 inch, exactly what I have and I can use the 12 inch one to connect to the wall (elbows add about 2 inch) which total 14 inch, a little shy from my current 17, maybe i can connect the 12+6 which will give with the elbow about 20 inch. I can't move much the stove but this is something i might try, worst case, I return the kit I guess i need to order it and play with it
