Double shagbark score
Discussion in 'The Wood Pile' started by Prometheus, Apr 9, 2021.
  1. Prometheus
    Prometheus
    Couple of shagbark hickories I started working on today out at my friend's farm.
    The first one is a blowdown from a three or four years ago. Judging by the spoor and a hollow section there's an active racoon den in the middle, so I'm cutting around that. I don't want the hollow part anyway. Probably close to 24" DBH. Bar was almost buried in the cut 1/3 of the way up the trunk. Jonsered 2166 with 24" bar was my weapon of choice.
    Supervisor judging my work. I guess he thinks I did OK.
    The second one came down last year. It's going to be trickier to get on the ground. There are a couple smaller trees under a lot of tension tangled in that brush. And the break is around 5-6' off the ground. I'm thinking of using straps and my truck to pull it down. Any suggestions?
    It was dry enough by the trees but way muddier than I thought it would be on the way in, so I'll need to wait a few days to get back there to finish up. But once I'm done this should be a solid year worth of wood for us. Will be for winter 2022/2023.
  2. wildwest
    Wyoming high plains
    Cute, your dog looks like it's smiling :)
  3. jo191145
    jo191145
    Ct
    Always nice to shag a little shag. As for the tricky one,,start at the leafy end and work backwards. It’s great when Mother Nature holds them off the ground for you.
  4. Ohio
    Not Ohio
    Great score and good lookin dog.
  5. Prometheus
    Prometheus
    Good call. I'll see how far I can get without sketchy strapping.
  6. Prometheus
    Prometheus
    Thanks, yeah he's a pretty handsome pupper. Balances out his stubborn ways ;)
  7. Horkn
    Shagbark score and a great looking dog. Nice work!
  8. mr.finn
    mr.finn
    Mass
    I love SBH. How does the stuff on the ground look? I have found that hickory will turn punky if left alone. A trick for the trees under tension, make a bunch of small relief cuts on the backside and it will start to relieve all the pressure. Love the dog!
  9. Backwoods Savage
    For sure I would not try to get it down. Cut as much as you can and by the time you have to stop, then you can just cut it to make the rest fall. If you are smart you will lay a couple short logs to fell it on so that part will also be off the ground. It surely is nice to get hickory!
  10. amateur cutter
    This answer to getting the tree cut up.
    I absolutely love the dog! He looks very intelligent.
  11. Erik B
    Erik B
    Western Wisconsin
    It has been my experience, when dealing with saplings under tension from a blow over, if it has been a year or more a lot of the tension is gone. The saplings start acclimating to the bent over position. mr.finn is right about cutting those under tension from the back side.
    Chazsbetterhalf, Prometheus and Horkn like this.
  12. Locust Post
    Brothers from another mother
  13. jrider
    jrider
    Hope there’s not too much rot. My experience with hickory has t been good when left on the ground in log form for too long.
    Chazsbetterhalf and Prometheus like this.
  14. Prometheus
    Prometheus
    Not bad so far. I'll report back once I have it all cut up. You can't tell from the pictures but between the root ball, a couple limbs in the middle, and a limb at the top end most of the tree is suspended a few inches off the ground, so I think most of it will be ok.
  15. Prometheus
    Prometheus
    Not too punky so far. 24" bar for scale.
  16. woody5506
    woody5506
    Upstate NY
    That's some back breaking wood there. Heck of a score. Love me some hickory but man is it heavy stuff.
  17. Prometheus
    Prometheus
    Yeah that ones gotta be over 200 pounds. No way I was going to lift these into my truck. I’ll bring a trailer in next time and roll em up the ramp.
  18. buZZsaw BRAD
    X2 I had to noodle the shag i cut in March to load it.
  19. buZZsaw BRAD
    Have you tried sectioning them with a maul Prometheus ? Fresh cut it splits somewhat easily IME provided its nor gnarly.
  20. Prometheus
    Prometheus
    I was thinking about giving that a shot. I do bring my fiskars out when I’m in the woods, but today I was just cutting. I’ll have the trailer out next time so I can go with whatever works best. My splitter goes vertical so heavy rounds won’t be an issue once I’m home.
    MikeInMa, Ronaldo and buZZsaw BRAD like this.
