This is a great marksmanship drill that came from David Blinder at personaldefensetraining.com. Start at 3 yards. You have to get all 50 hits to pass. Once you can shoot the whole drill without a single miss, either increase the distance or add time pressure. For instance, try to finish the entire drill in under 5 minutes while maintaining 100% accuracy. Dot 1 – Draw and fire one string of 5 rounds for best group. One hole if possible, total 5 rounds. Dot 2 – Draw and fire 1 shot, holster and repeat X4, total 5 rounds. Dots 3 & 4 – Draw and fire 1 shot on #3, then 1 shot on #4, holster and repeat X3, total 8 rounds. Dot 5 – Draw and fire string of 5 rounds, strong hand only, total 5 rounds. Dots 6 & 7 – Draw and fire 2 shots on #6, then 2 on #7, holster, repeat X4, total 16 rounds. Dot 8 – From ready or retention, fire five shots, weak hand only, total 5 rounds. Dots 9 & 10 – Draw and fire 1 shot on #9, speed reload, fire 1 shot on #10, holster and repeat X3, total 6 rounds. There is also a dedicated TDA (Traditional Double Action, aka “DA/SA”) version created by Sean Leffler: Dot 1 – Draw and fire two pairs (first shot DA, second shot SA) for best group. One hole if possible, total 4 rounds. Dot 2 – Draw and fire 1 shot (DA), holster and repeat for a total of 4 rounds. Dots 3 & 4 – Draw and fire 1 shot on #3 DA, then 1 shot on #4 SA, holster and repeat three more times, total 8 rounds. Dot 5 – Draw and fire three pair (first shot DA, second shot SA each pair), strong hand only, total 6 rounds. Dots 6 & 7 – Draw and fire 2 shots on #6 (first shot DA, second shot SA), then 2 on #7 (both SA), holster, repeat three more times, total 16 rounds. Dot 8 – From ready or retention, fire three pairs (first shot DA, second shot SA), weak hand only, total 6 rounds. Dots 9 & 10 – Draw and fire 1 shot on #9 (DA), reload, fire 1 shot on #10 (SA), holster and repeat two more times, total 6 rounds. Training with firearms is an inherently dangerous activity. Be sure to follow all safety protocols when using firearms or practicing these drills. These drills are provided for information purposes only. Use at your own risk. Source: http://pistol-training.com/drills/dot-torture
Do I get extra points (hits) if I fire while drawing and hit my foot... Your gettin me thinkin' about shootin' some. Wish I could find a decent local dealer for .22 mag and .22 LR. What's a brick of LR go for, if you can find em?
I don't think you get extra points for "Fifing." I think they were $20 when I found them that one time... Haven't found any since.
