Donkey Starting and unloading a old D-9.........................
Discussion in 'Everything Else (off topic)' started by rottiman, Dec 13, 2016.
  1. rottiman
  2. Backwoods Savage
    Just think about the amount of power it takes just to make that thing move and that will give you an idea of the total power it has. One can tear down lots of stuff with that thing. I was never lucky enough to run one that big.
    basod, Jeffrey Svoboda and papadave like this.
  3. rottiman
    Imagine trying to start it when the temp. is below zero........................
    Backwoods Savage and papadave like this.
  4. DaveGunter
    DaveGunter
    Any clue why they offloaded to the side?
  5. rottiman
    Looks like the roadway was saved by dropping it on the dirt. It would be a pavement eater with those tracks and weight.
  6. basod
    basod
    Mount Cheaha AL
    that's what the gas engine is for;)
    I've run one as awesome as they seem that sucker will break your kidneys
    Backwoods Savage and rottiman like this.
  7. Bgoathill
    Bgoathill
    Dumont, Ia
    I think they probably start better than the new ones. Fire the pony up and let her run for a half hour or so, it warms up the oil and coolant for the big motor, plus the exhaust acts as a preheater for the intake air. I didn't know if my D6T was going to fire this morning. The computer won't send fuel to the injectors until the oil pressure reaches a point, and the batteries must be getting a little weak. She was just starting to run down and she finally fired. It wasn't even that cold, about 5 above.
    Backwoods Savage, rottiman and basod like this.
  8. basod
    basod
    Mount Cheaha AL
    Obviously the expense of adding the gasser with all the newer emissions constraints is why they went to block heaters and glow plugs.
    At the time when diesels had minimal technology - it was a nifty add-on that solved the problem.
    Our Cat telehandler at work has no block heater and struggles with glow plugs below 30. Even more frustrating is the glow plugs will not even engage if the ambient sensor is above some set point
  9. DaveGunter
    DaveGunter
    Tore the deck of the low boy up
    rottiman likes this.
  10. Backwoods Savage
    Did it tear up the deck or was that just slabs they put on the deck to protect it? The slabs will get torn up rather than tearing up the deck.
    Jeffrey Svoboda likes this.
