DOLMAR 6100 OR 7910?
Discussion in 'Chainsaws and Power Equipment' started by MICHIGANSAWER, Apr 15, 2015.
  1. MICHIGANSAWER
    MICHIGANSAWER
    michigan
    Well first post so here it goes... Apparently someone needed my Efco 165 worse than I did as its now missing from its normal resting place. :mad: So its off to the dealer who now also carries Dolmar saws. Tested out a 6100 and really enjoyed it. I've been wanting to step up a class or to size wise for some time. Just not sure it warrants the extra $??? This is strictly a firewood saw. Will run a 20 inch bar 90% of the time with the need for up to a 24-28 inch bar on occasion. This being said what are everyone's thoughts on these 2 saws. Thanks.
  2. cgraham1
    cgraham1
    Nor Cal
    If you really do need to run a 28" bar on occasion, then the 7910... if you can make due with a 20" bar for most wood, the 6100 would be fine. It won't pull a 28" bar worth a crap, and definitey won't oil it either. I believe it's a K095 (small Husky) mount and I'm not sure you could even find a 28" bar for that mount, anyways. Dolmar recommends a max bar length of 20", BtW.
  3. w8ye
    w8ye
    Mansfield, Ohio
    As has already been posted . . .
    Dolmar 6100 has a small mount Husqvarna bar mounting pattern (Oregon K095)
    Dolmar 7910 has a large mount Husqvarna bar mounting pattern (Oregon D009)
    I have a Dolmar 7900. Though it will pull a 32" bar in most situations, 28" is considered the maximum length due to oiler limitations unless you are in green wood.
    splitoak likes this.
  4. millermodsaws
    millermodsaws
    That's a $300 question right there. Lol. I agree with what's been said. If it will wear a 20" bar most of the time than a 6100 will be hard to beat. However a 7910 with a 24" bar is gonna bring a big Ole smile to your face everytime you run it.
  5. bassJAM
    bassJAM
    Cincinnati, OH
    Is this your only saw? If so I'd go with the 6100 for the weight alone. My 7900 wears a 20" most of the time, but it sure gulps the gas and can get heavy.
    Eric VW and PullinMyPoulan like this.
  6. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Is there a reason you're looking at the 6100 and 7190 but not the sizes in between? 7910 is overkill if it usually wears a 20", but right if it's usually wearing a 28".
    A 6400 or 7310 might be best, really.
    Eric VW likes this.
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    Welcome to FHC.
    All the info above is great stuff!
    For 28" hands down the 7900/7910.
    If 20" will meet your needs? Then 6100 will do just fine!
    clemsonfor, crzybowhntr and Eric VW like this.
  8. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    jeff_t and DexterDay like this.
  9. jeff_t
    jeff_t
    SE MI
    :emb:
    If you're gonna lug around a 64 or 73, you might as well have the 79. They all the same.
    The only reason I don't have two 7900s is because the 6401 is too dang good to mess with.
  10. cgraham1
    cgraham1
    Nor Cal
    Exactly how I see it... They are the same saw, other than the P&C.
    clemsonfor and concretegrazer like this.
  11. dgeesaman
    dgeesaman
    Elizabethtown, PA
    OP was talking $$ differences. Functionally, I agree with you.
    clemsonfor likes this.
  12. MICHIGANSAWER
    MICHIGANSAWER
    michigan
    This will be my only saw for the time being. I am considering the 6100 because of the design and the filter setup. I liked the feel of the demo saw I ran. It had a 24 in bar and the power was spot on. The 6400 seems too heavy for a 60cc saw, and like the others have said 7910 is the same chassis. Just unsure about lugging around a 79cc firewood saw. My cutting buddy runs a 395xp with a 20 inch bar as his only saw. I know I'm not cutting as fast but feel just as productive at the end of the day because of less fuel stops. The power to run a longer bar than 24 inches is what is tempting me to step up. The need for a long bar should be minimal but the ability to take on bigger wood would be a bonus.
    $ooline and PullinMyPoulan like this.
  13. millermodsaws
    millermodsaws
    For the money the $300 difference is huge if you consider the alternitve. 2 saw plan is better especially if you ever cut bye yourself. You can almost buy a new ps421 and ps6100 for the price of the 7910. Then if you get pinched or what not you have a back up. Plus at 10 lbs it's so much easier on the back for limbing and etc. Then later on add the 7910 and you have a collection fit for a king. IMO!
    MasterMech, clemsonfor and maulhead like this.
  14. MasterMech
    I really like the 6100 and think you'd get a lot of saw for the $$. You might have to make two cuts on the occasional big trunks but occasionally wishing for a larger saw beats always regretting dragging around unnecessary bulk. I'd get the 6100 and buy a bigger bar and chain for your buddy's 395. :p
  15. maulhead
    maulhead
    Colorado
    Is that what the price difference is on a 6100 vs a 7910, $300? I never priced a 7910. One of the local Stihl dealers also sells Dolmar, I was there last week getting some Stihl things, and he had a 6100 on the shelf, 1st one I've seen in person.
    They look like a nice saw, heck of a lot cheaper price wise then the 362c,, Kind of wish they would have had them around a year-1/2 ago when I bought the 362c... I would like to have a 6100 someday I think...
    CTYank and $ooline like this.
  16. $ooline
    $ooline
    WI
    for a 20'' bar the 6100 would be logical hands down but if you like to mess with more hp albeit more weight like i do, then get the 7910 and see if you can show your buddy and his 395xp a thing or two
  17. dgeesaman
    dgeesaman
    Elizabethtown, PA
    You're an optimist - the 7910 is 15cc less displacement than a 395xp.
    David
    splitoak and bryanr2 like this.
  18. concretegrazer
    concretegrazer
    Southwest MO
    With a 20" bar neither will break a sweat. My money is on the one with the better chain.
    Moparmyway, Hedgerow, mdavlee and 4 others like this.
  19. clemsonfor
    Do t this k I would run more than a 20 on a 6100.
    If that is only saw you buy and the price diff I would say smaller saw and cut from both sides.
    If you have the cash get the bigger saw. You can then cut anything.
    And I bet he is more productive with a bigger saw than you unless y'all but 10" wood all day.
  20. $ooline
    $ooline
    WI
    as i see others have already pointed out, with a 20 inch bar the 395 doesnt outrun a 7910. Got get into the long bars to take advantage of that extra 15cc
    mdavlee, DexterDay and maulhead like this.
