Doh!! Messed up.
Discussion in 'Chainsaws and Power Equipment' started by jo191145, Nov 13, 2019.
  1. jo191145
    jo191145
    Ct
    Dang it. Tough being blind.
    Had bought two chainsaws thru FB. A 361 and 550. 361 came with different bars and chains. Had bought different bars and chains for the 550. So I had a bunch of bars and loops sitting in the same box. They’ll only fit what they fit so I didn’t keep anything segregated.
    Well I switched to the longer bar on the 361 a while back. Found a loop that fits. Didn’t look at anything just put it on and started cutting.
    Yesterday I touched some dirt with it. Needs a sharpening. Took it off, mounted it in the grinder and went to work. Noticed the original grind was a little strange. It’s Oregon, they do strange things, just keepa go.
    About five teeth in I really took a good look.
    It’s square filed chain dammit.
    I didn’t even know you could buy it that way from the factory. Too late now.
    No wonder my impression of Oregon 3/8” chain was improving. Idiot.
  2. Marvin
    Marvin
    Huntingdon, Pa
  3. amateur cutter
    Oops lol, I can see me doing that. Good luck fixing that.
    Horkn, M2theB, jo191145 and 1 other person like this.
  4. jo191145
    jo191145
    Ct
    Yeah there’s no fixing that :) no choice but make it all round at that point.
    amateur cutter, Horkn and M2theB like this.
  5. LinkedXJ
    LinkedXJ
    Indiana
    Dangit!
    amateur cutter, Horkn and jo191145 like this.
  6. Nixon
    Nixon
    West Sunbury,Pa .
    If you were closer ,you could drop it by here ,and I’d sort it for you . Maybe check into USPS flat rate prices . If it’s cost effective to you , I’d be glad to true it back up .
    Also, it might be a great opportunity to get a couple of files ,and learn to square file .
  7. The Wood Wolverine
  8. jo191145
    jo191145
    Ct
    Appreciate the offer. That’s very nice of you. Unfortunately I was a very patient young man. Seemed to have burned all my patience up years ago. Lost my will to learn and spend time making things better. I don’t even hand file round chains. Run em till they dull up and grind em.
    Thanks again.
    amateur cutter and Horkn like this.
  9. amateur cutter
    Simington square grinder? Readily available if ya wanna drop a grand.:whistle:
    The Wood Wolverine and jo191145 like this.
