Does Temperature Affect Moisture Meter?
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Dec 11, 2019.
  1. buZZsaw BRAD
    I was moving some 9 month seasoned ash splits today. Some of them were heavier than the rest. Split one and internal moisture was below 20% to my surprise. Im wondering if the cold affects the MM? I keep it in my truck. Any thoughts?
    EDIT: just read the owners manual and it states operating temperature from 32-104* f or 0-40* c
    farmer steve, Slocum and mat60 like this.
  2. brenndatomu
    Yes...the wood must be room temp or so...the meter itself, I dunno, good question. My guess would be yes.
  3. mat60
    mat60
    ME
    No... That would be my guess.. I cant find any info on this.
    Slocum and buZZsaw BRAD like this.
  4. Felter
    Felter Banned
    chicago
    of course temp affects a MM. . . MM measure resistance to electrical current, not moisture.
  5. Slocum
    Slocum
    North Central Indiana
    I’ve read that it does but I’ve used mm when it was 15 outside and then took the piece inside and let warm up and only had a 1% difference. If you have the time do a little test and see.
    fox9988, mat60, billb3 and 1 other person like this.
  6. billb3
    You can find charts online with the differences of temp and your 1% is often in line with the results on those charts.
    Many meters auto compensate for temperature as long as you are within around 10 degrees to 90 degrees.
    Many meters are not accurate under 10 degrees and some are not accurate above 90.
    Considering the average person really doesn't do a relatively robust enough sample size for an accurate representation arguing about temp range accuracy of an unknown meter is rather moot.
    Still beats knocking two splits together.
    Felter, Slocum and yooperdave like this.
  7. Mag Craft
    Mag Craft
    South East Wyoming
    Maybe there is a recommended temperature range.
    Felter, Slocum, yooperdave and 3 others like this.
  8. moresnow
    moresnow
    Many meters are calibrated to be accurate at 70F. Reasoning for splits being brought to room temp for testing etc. There is a link in one of my posts recently that is a good read on this topic. If I can find it I'll post it here.
    Now where did I post it??
    Felter, yooperdave and mat60 like this.
  9. buZZsaw BRAD
    just read owners manual. (luckily didnt throw it away) 32-104* operating temp. It was in the mid to upper 30's this afternoon.
    fox9988, Felter, MikeyB and 4 others like this.
  10. Mag Craft
    Mag Craft
    South East Wyoming
    I thought I had read in the manual I got with my meter that there was a temp range but it has been awhile and did not want to say for sure.
    I was not as smart as you and threw out my manual.
  11. iowahiker
    iowahiker
    NE Iowa
    Temperature does change moisture meter results. Increase the moisture meter reading by approximately 1% for every 20 deg below 70 deg F (if the meter does no auto correct). A meter reading of 18% moisture at 32 deg F is actually 20% moisture.
    My meter measures and displays the air temperature, but the instructions do not say if the meter does or does not do the temperature adjustment. If the measurement is important than I bring the wood inside for a day and then split the wood outside and measure the moisture quickly before the wood cools off (with the grain). For a quick approximation, I just measure the cold fresh split moisture and figure it is actually 1% or 2% higher if the wood is at 50 deg or 32 deg.
    edit: I just looked in the meter manual and it says not to use the meter below 32 deg F.
  12. Paul bunion
    Paul bunion
    Felter likes this.
  13. farmer steve
    farmer steve
    top of the hill york co. PA.
    Real men don't need manuals!! :rofl: :lol: I doubt I stihl have mine.
    Mag Craft, buZZsaw BRAD and Felter like this.
  14. farmer steve
    farmer steve
    A weak /old battery may also give you inaccurate readings. I keep mine in the heated shop most of the time.
  15. mrfancyplants
    mrfancyplants
    South Carolina
    I like how it is presumed to be tested inside... and freshly split. I’d like to see what Mrs. FancyPlants says when I get set up to do some splitting in the living room.
    farmer steve and buZZsaw BRAD like this.
  16. buZZsaw BRAD
    i just bought the MM late last Winter and keep it in the box so it was still in there. Dont really use it a lot.
