Diesel Prices!
Discussion in 'Everything Else (off topic)' started by Fanatical1, Jul 31, 2014.
  1. Fanatical1
    Fanatical1
    Drove by this Speedway near Dayton this week and had to do a double take.....o_O
    campinspecter, Drvn4wood and Stinny like this.
  2. Trundle
    Trundle
    NW Montana
    Whoa. That's gotta be a signage malfunction. We're around 3.90 a gallon in NW Montana right now. Still pretty spendy.
  3. yooperdave
    Perhaps the same guy speculating the price of LP (last spring) got moved over to Diesel??
    concretegrazer likes this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Typo for sure. I think we are around $3.88 around here.
    I miss my diesel truck but not the price of fuel for it.
    Cheaper to process yet big money to purchase. Back in 2002 when I was
    buying it, it was less than gasoline.
  5. chris
    chris
    SE WI
    That all pretty much changed with EPA mandates on pulling out the sulfer. Course now ya got to go buy lubrication additives and with the news units that DEF stuff also. Diesel fuel has been hanging around the $4 mark here with gas about $0.50 cheaper for 87 octane of the ethanol laced stuff. Problems with the Ethanol mix ratio have been creeping up seems that the supply companies are not being to careful how much they add. Been reports of up to 28% by volume. Note that the refineries are not the ones doing the mix more a regional distributor situation. At any rate it is burning way to hot in small engines 4 and 2 stroke with the 2 strokes taking the brunt of it.
  6. Bret Hart
    Bret Hart
    Central NY
    Diesel is right around $4.15 here and with the loss of sulfur I started adding 2 cycle to it to save the VP44 pump on the Cummins. Did bump my mileage up about 1 to 1.5 mpg though.
  7. nate
    nate Banned
    Palmer, AK
    I run normal sulfur fuel in most of my stuff. Oddly enough that killed 2 VP44s.
  8. Bret Hart
    Bret Hart
    Central NY
    Aftermarket or OEM lift pump? Fuel pressure gauge?
    Pressure to the VP44 should never get below 14psi even at WOT. Pump is cooled by extra fuel and anything below 14psi won't get by the bypass or relief valve and circulate back to the tank. Most VP 44 failures are the electronics overheating and burning up according to those that re-manufacture them.
  9. nate
    nate Banned
    Palmer, AK
    Pump seized.
  10. stuckinthemuck
    stuckinthemuck
    I think it's the other way around.. The speculators have been in the distillate market for a long time controlling diesel and jet fuel prices through the much smaller home heating oil trading market.
    http://online.wsj.com/news/articles/SB110971828745967570
  11. Stinny
    Musta brought in customers like flies... :picard:
    Fanatical1 likes this.
  12. Fanatical1
    Fanatical1
    Obviously it was a problem they were having, but you would think they would need to fix it pretty quickly. :bug:
    It couldn't have been good for business..... and unleaded was also $8.88, but on their smaller sign.
    Stinny likes this.
  13. clemsonfor
    Didnt think they still made LSD thought it allwas ULSD?
  14. Woodwidow
    Must have posted the Canadian price for diesel!!!
    campinspecter likes this.
