Diagnostic needed
Discussion in 'Chainsaws and Power Equipment' started by FatBoy85, Apr 3, 2018.
  1. FatBoy85
    FatBoy85
    Washington State
    My 026 is having some issues. I can start it but not with the chain brake on. When it starts, blades and engine run hard until I give gas then it tends to die shortly after. Engaging the chainbrake will stop it altogether. Let me know what you guys think...
    Barcroftb and M2theB like this.
  2. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    My old Craftsman does the same thing......interested to learn the causation-
    :popcorn::popcorn:
    Barcroftb and FatBoy85 like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    You may have an air leak.
  4. huskihl
    huskihl
    Clutch drum bearing is shot or needs grease
    Barcroftb, M2theB and FatBoy85 like this.
  5. FatBoy85
    FatBoy85
    Washington State
    Is this one an expensive fix? I’m leaning towards this as the brake has effect...
    Barcroftb likes this.
  6. huskihl
    huskihl
    Not at all, if in fact it is the culprit. Hard to diagnose over the net. It could also have weak clutch springs causing the chain to spin at idle. But in either case, it should still idle, although maybe at slightly lower rpm. Could also be poor carb settings or an air leak
    Here's a drum bearing from a member here
    New OEM Stihl clutch bearing Chainsaw many models 9512 933 2260 026 036 more 5055485023575 | eBay
  7. 94BULLITT
    94BULLITT
    It could have a bad clutch bearing but I with it dying when he trys to throttle it up, I think it has something else wrong. It could be as simple as a carb adjustment, but how did the carb get out of adjustment enough to where it wont run.
    Barcroftb, FatBoy85, M2theB and 3 others like this.
  8. huskihl
    huskihl
    I think you're right. Now that I read his original post again, he has a little bit more going on there, doesn't he
  9. 94BULLITT
    94BULLITT
    I read it wrong the first time myself. I thought he said it would only start with the chain brake on. Then I saw what you said and went back and read the original post.
    Barcroftb and huskihl like this.
  10. 94BULLITT
    94BULLITT
    How old is this 026? Has it been sitting for an extended period of time?
  11. M2theB
    M2theB
    Central Massachusetts
    Can you make the symptoms go away if you baby the throttle until the saw gets hot?
  12. FatBoy85
    FatBoy85
    Washington State
    No it would sit but not neglected. Until now I’m waiting for better days to get back to this. If I could take a video of this maybe it could help ?
  13. FatBoy85
    FatBoy85
    Washington State
    Somewhat but the problem was I think I let it idle too long. It smoked like crazy and then shutdown.
  14. bang
    bang
    South central Indiana
    1st thing I would do is drain all the fuel and add fresh then change the spark plug and clean the air filter, probably not the issue but eliminate those as possibilities. Set the carb at the original settings which iirc are 1 1/4 on both needles. If you still have the same problem I guessing you need a carb rebuild or as some do just put on a new aftermarket carb. I have good results either way but I cycle carbs in a ultrasonic cleaner and I think that is required in some cases.
    Maina and FatBoy85 like this.
  15. Nixon
    Nixon
    West Sunbury,Pa .
    Sounds more like an airleak rather than a carb adjustment ,or clutch problem . Check your impulse line and carb boot for tears . Also check your fuel line for holes . If you can , pressure vac test it . The FW side seals can also be problematic on this saw . I wouldn’t run it until you elimiminate air leaks as a possible cause .
    Maina, M2theB, FatBoy85 and 1 other person like this.
  16. Barcroftb
    Barcroftb
    The Mitten
    Sounds like an air leak. If this saw is equipped with a decomp valve it could be malfunctioning and causing an air leak.
    Maina, Horkn, M2theB and 1 other person like this.
  17. FatBoy85
    FatBoy85
    Washington State
    Ok I’ll get this looked at soon. Thanks fellas. Good thing I have a back up.
    Maina and Nixon like this.
  18. Nixon
    Nixon
    West Sunbury,Pa .
    I hope it’s an inexpensive and easy fix . Lets us know what the cause was . It’s always good to know what cures a particular problem for future reference .
  19. 94BULLITT
    94BULLITT
    A video probably would not help. I would start by looking at the fuel line closely.
    FatBoy85 likes this.
  20. FatBoy85
    FatBoy85
    Washington State
    I agree! It’s in the notes for the project. I want to have that chance where I actually sit or stand and work into this thing. The chance will come up very soon,
    Nixon and Maina like this.
