Determing RPM based on sprocket size
Discussion in 'The Sawyer Room' started by Sawdog, Mar 19, 2015.
  1. Sawdog
    Sawdog
    im hoping somebody will be able to steer me in the right direction.
    I'm looking to determine final RPM of a chainsaw mill I'm building based on the sprocket size. In other words, if im using a 15HP motor at 3200 rpm with a 1" shaft and I use an 11 tooth sprocket, what would be my final chain RPM?
    Is there a standard formula I can use as I decide to make changes to my mill or need to make sprocket changes? Is there a standard rpm suggested range for chainsaw mills, etc, etc? I'm using a 6' bar at the moment. Any info would be a great help - thanks!!
  2. Shawn Curry
    Shawn Curry
    Western NY
    This is just off the top of my head. RPM of sprocket * circumference of sprocket = chain speed in FPM, which is how it's usually measured I believe. Normal crosscutting chain speed is around 5000FPM I believe.
    Found this - gives a formula to convert from chain pitch: http://www.sawmillchainsaws.com/sawfacts.htm
    Sawdog likes this.
  3. Sawdog
    Sawdog
    Thanks Shawn!
    Does anyone know if there Is there a suggested milling speed (feet per minute) for rip cuts?
  4. MasterMech
    Just curious as to what you are using for an engine?
  5. Sawdog
    Sawdog
    15hp lawn mower engine i had sitting around.
