Cutting Splits
Discussion in 'The Wood Pile' started by Skier76, Jun 23, 2024.
  1. Skier76
    Skier76
    CT and SoVT
    I’d like to tap into the collective brain trust of FHC for some advice and inspiration.
    I’ve got maybe a face cord of ash that fell this Fall in CT. It’s been cut, split and stacked since December; splits are about 18” long. Our firepit takes wood that’s 12” long.
    Sooooooo! I’m looking for a good way to cut these splits; thinking of making up some type of jig to hold them and then just run the saw down. I know I’ve seen some threads in the past where some folks here have done something similar. At first, I thought I’d cut them to 12”. But that leaves me with a bunch of 3” chunks. So at this point, I think I’ll just halve them and call it a day.
    Here’s the wood:
    And here are some 2x’s I grabbed from up north this weekend:
    Open to any suggestions and/or pics you have to share.
  2. spotted owl
    spotted owl
    PNW
    Pictures of the fire pit?
    It’s been a while but I used tied down straps about 6” apart. Cumbersome and a pain but it worked and held(a lot) everything secure for the cut. I couldn’t make a jig secure enough for the situations “help” at the time.
    Owl
  3. Eggshooterist
    Eggshooterist
    Erff
    Do you have a 12" miter saw?
  4. JDU
    JDU
    Perry County, PA
    Build a bigger fire pit? :D:D
  5. buZZsaw BRAD
    Put the 18" splits vertical in the fire pit? :D
  6. MikeInMa
    Use ratchet straps on each end of a number of splits. Run the saw down the middle.
    Wash, rinse, repeat as needed.
  7. markf
    markf
    Flushing MI
    Maybe you could use a 12" chop saw....if you have one?
  8. EODDiver
    EODDiver
    Nashville, TN
    Have been there done that for a few firewood customers that wanted 8-10” splits. Cutting in half is easiest. Line the wood along a board or pallets for cutting. Best to have another person removing and feeding your work as you cut. Heavy steel toed boots help hold the wood in place while cutting. Take your time.
    metalcuttr, Biddleman, JDU and 3 others like this.
  9. buzz-saw
    buzz-saw
    Ct.
    I bought a cheap/used miter saw from a local papers for sale ads. I use it for cutting splits for the cooker. $25 well spent
  10. Backwoods Savage
    Hum. Please check my math as I'm not too good at it but it seems to me you would end up with 6" pieces. Nothing wrong with that but also nothing wrong with burning 9" pieces in the fire pit.
  11. The Wood Wolverine
  12. RCBS
    RCBS
    Over here
    I've done it without a jig or anything right on the stack. It ain't pretty but does work once you figure how to orient yourself/guide bar.
  13. Skier76
    Skier76
    CT and SoVT
    Thanks all!
    Jason, thank you for that pic. That’s the thread I remembered from awhile back; appreciate you linking it. I’ll probably fab something up like that.
    Here’s a pic of the firepit. It’s a Solo Stove Ranger in a stone housing. So there’s not room for bigger splits. The Solos burn better when the wood is under that top fire ring. With dry wood and it loaded correctly, it’s a great smokeless burn that puts out some good heat. This project was wrapped up a few weeks and we’ve spent many nights out there relaxing after dinner.
  14. The Wood Wolverine
    Two thumbs up on the firepit and surrounding area! Looks great. :thumbs:
  15. Skier76
    Skier76
    CT and SoVT
    Thanks! We had an extension built off of our back patio. Unfortunately the pavers we used for that project (over 15 years ago) were no longer available. My wife came up with the pea stone solution and using a few extra pavers we did have as a boarder. The mason did an awesome job.
  16. John D
    John D
    Syracuse ny
    That’s a really nice job
  17. buzz-saw
    buzz-saw
    Ct.
  18. Skier76
    Skier76
    CT and SoVT
    This worked well! Not bad for using some scrap wood I had laying around. Should be good for cutting up the rest of the splits.
    metalcuttr, eatonpcat, John D and 5 others like this.
  19. Backwoods Savage
    Looks a lot like mine except mine is so no bending is required when cutting. It helps to save the back.
    metalcuttr, eatonpcat, John D and 3 others like this.
  20. The Wood Wolverine
