Cutting cookies
Discussion in 'The Sawyer Room' started by schlot, Jul 17, 2016.
  1. schlot
    schlot
    NW Iowa
    I volunteered to cut some cookies for my niece as centerpieces for her wedding.
    I don't have anything like a bandsaw so do you guys have any ideas, besides a good eye and steady hand to help me to make nice even cuts?
  2. thistle
    thistle
    Polk/Guthrie Counties,IA
    Very sharp chain,keep feet planted in one spot.Move arms/shoulders when needed but don't move feet while in the cut otherwise you lose accuracy.
  3. ironpony
    ironpony
    Mid Ohio
    My wife just uses a "cookie" cutter, they come in all shapes ...............
  4. brenndatomu
    This ^ ^ ^
    I'd go one further on the chain though, I'd consider a new one...they always seem to cut the straightest.
    And a nice straight log would have to make it easier to maintain a straight/square cut I would think...but what do I know...my expertise is cutting cheese :whistle:
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    whats the width and thickness of the centerpieces going to be?
    Eric VW likes this.
  6. TurboDiesel
    Getting the log up and off the ground and level may help
    Eric VW, Shawn Curry, lukem and 3 others like this.
  7. schlot
    schlot
    NW Iowa
    I haven't heard back but I was going to suggest 2"
    My IS heats my home and Eric VW like this.
  8. Chvymn99
    Eric VW likes this.
  9. lukem
    What diameter?
    If they are small enough for a miter saw...use it.
    If not...a few reference marks with chalk will help keep them even.
    Eric VW likes this.
  10. brenndatomu
    Get to thinking about this a lil more...If you have a fairly straight log, you could mark it the way you mark a large pipe to cut it, a pipe wrap. All you would need to pull this off DIY style is a strip of cardboard about 3-4" wide and long enough to wrap clear around the log with some overlap. Once it is wrapped around the log, and the sides of the overlap lined up, just use the edge to make a straight mark with chalk or whatever...
    Eric VW, Chvymn99 and schlot like this.
  11. schlot
    schlot
    NW Iowa
    No....unfortunately too big.
    Eric VW likes this.
  12. lukem
    As long as the log is stable and you have a couple reference marks it is easy enough to do with a chainsaw. Worst case scenario you end up with a little extra firewood. Not rocket surgery.
    Eric VW and schlot like this.
  13. Greg
    Greg
    I just eyeballed mine, cut a bunch shooting for about an inch in thickness.
    Sharp chain for sure (factory sharp) and don't use saw teeth to dig in , keep saw motor off log by a few inches and lit chain make cut on its own with no leveraging against teeth
    Last thing is to get two coats of Polly on them within a week or so, as they will be thin and can check within a few weeks if kept outside in sun.
    Straight log also key of course
    Happy cutting, you saving them some money and they will look great I'm sure!
    Eric VW, Shawn Curry and schlot like this.
  14. schlot
    schlot
    NW Iowa
    Is rocket surgery very fast AND accurate? Or would I have worry about a doctor taking out my spleen AND my appendix...just VERY quickly? :)
    Eric VW and Shawn Curry like this.
  15. lukem
    Surgery while travelling at 17,000 MPH and 4 G's.
  16. Shawn Curry
    Shawn Curry
    Western NY
    I just eyeballed the ones I did. They don't need to be perfectly consistent; in fact a little variety in thickness can provide some visual interest. I did try to keep the cuts parallel, in case they wanted to set up candles or something on them so they wouldn't slide off.
    Of course, I put the logs up on my sawbuck - I sure wouldn't want to cut a whole mess of cookies from a log on the ground. I also held the saw toward the center of my body so I could sight down the bar better - normally I hold it more to my right side.
    fishingpol, schlot, Thor and 2 others like this.
  17. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I was thinking to take a camping wire saw and wrap it around the log once. A quick back and forth and there is a scribe mark in the bark all around.
  18. Gunn
    Gunn
    Plover, Wi
    I used an Alaskan mill to make our center pieces. Once I figured out the right thickness, I made short work of the cookies.
    My IS heats my home and schlot like this.
