Crawl space encapsulation
Discussion in 'Everything Else (off topic)' started by Nitrodave, Feb 10, 2017.
  1. Nitrodave
    Nitrodave
    Grayling Mi.
    looking into getting my house in Grayling, Mi. done. Any experience, recommendations, horror stories etc ? Crawl is 24'x48'x28" and in pure sand, so dry and no standing water.
    Backwoods Savage and papadave like this.
  2. Scotty Overkill
    I have a crawl space under our living room, I was thinking about the same thing. Spray foam on the underside of the floor and a skimcoat of cement on the dirt.....
  3. fox9988
    fox9988
    NW Arkansas 72717
    I know someone who had it done with cellulose, sprayed right on the blocks. They said it made a very noticeable difference. ~5 years and no problems.
    Backwoods Savage and Brad38 like this.
  4. papadave
    Should be no cost to have some estimates done.
    If it's fairly open and easy access, a crew might get that done in a day.
    You'll likely notice a big increase in comfort level and a decrease in energy use.
    Insulation is da bomb.
    If you have the means, do it.
  5. intheBigWoods
    intheBigWoods
    central North Carolina
    I had ours done a few years ago. I highly recommend it. Used a very heavy duty thick white vinyl on the floor/dirt/sand, all taped together and sealed. Then a spray foam on the walls covering the turned up edge of the vinyl on the floor. Very clean, it's all white and bright. Looks like the inside of an igloo. It becomes part of the conditioned space. Every house with a crawl space should have it sealed.
  6. yooperdave
    Is there still a need for ventilation or not?
  7. Backwoods Savage
    Be very careful as it has been said that the ghost of Papa Bear still prowls around that area.
    Nitrodave likes this.
  8. Nitrodave
    Nitrodave
    Grayling Mi.
    According to what I read.... no. The idea is to make it as sealed up as possible, and then some form of conditioning of the air. Either by a dehumidifier or simply adding a register from your hvac system.
    I currently have the dreaded fiberglass in the floor joist with a vapor barrier sheet. (manufactured house style) I still need to put a vapor barrier down on the dirt floor (code) I have noticed the mice do like the fiberglass. I was thinking about spray foam seal the foundation wall to sill, 3" polyiso on the walls then encapsulate the crawl. Just not sure if I have the time to do all this, or just pay someone to do it.
    yooperdave likes this.
  9. Nitrodave
    Nitrodave
    Grayling Mi.
    I think I saw him eating out of the bird feeders the other night.
  10. Nitrodave
    Nitrodave
    Grayling Mi.
    This is similar to what I have been researching.
  11. DNH
    DNH
    Missouri
    Cheap route is just putting down plastic and overlap it about 1' that's kinda the standard down here.
    I'm planning on doing a full encapsulation in the next few years. I've debated about 1" closed cell foam but will most likely use 1-2" rigid xps board from lowes and cut to fit around the rim joist and great stuff applied to the periphery. For the floor I will use a good 10-20mil white vapor barrier anchored and sealed to the wall. But that's money and time that is dedicated to other projects.
