Crank up your stove .
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Russell, Nov 10, 2017.
  1. Russell
    Russell
    South Coast , Massachusetts
    Show off your stove cranked up ! Finally running on high over here . It's reading 300 from the top vents and 410 from the box .
  2. bogieb
    Mine ain't even trying yet - keeping the house warm is easy with 2 stoves.
    CleanFire, ivanhoe, gbreda and 6 others like this.
  3. Russell
    Russell
    All cleaned and ready for the evening .:cheers:
    CleanFire, don2222, ivanhoe and 4 others like this.
  4. will711
    will711
    Pocono Mts.
    Ditto , never really had to crank mine up
  5. IHATEPROPANE
    IHATEPROPANE
    Same here, two stoves pretty much on low!
    CleanFire, slvrblkk, ivanhoe and 3 others like this.
  6. bogieb
    But, I felt bad for bragging, so took a pic of the P61a just after firing up after cleaning. Probably hasn't even hit 200* at this point.
    CleanFire, don2222, slvrblkk and 5 others like this.
  7. jtakeman
    I let mine rip for about an hour after coming in from working on da pickem up. Joey and I froze our backside a bit. Roasty now and back to medium...........
    CleanFire, slvrblkk, imacman and 3 others like this.
  8. ChandlerR
    ChandlerR
    Seacoast NH
    My digital temperature display died. 9 years and it was old when I got it. I have the electricians at the plant looking for another one for me. I hate flying blind! Now that I have the high capacity combustion blower, I would love to know how it's doing. My guess is if it's moving more air through the pot, the dwell time of the flame against the heat exchangers might be lower. Hopefully I will have another tomorrow.
    CleanFire, slvrblkk, imacman and 4 others like this.
  9. BHags
    BHags
    Massachusetts
    IMG_E1236.JPG IMG_1237.JPG It's an old school method, so take it for what it's worth. The stove is on 4 out of 5.
  10. Russell
    Russell
    Awesome stoves , you guys have some heat monsters . I like the old school thermometer 500 is cranking ! and you can't go wrong with cast iron or the P61A.
    CleanFire, slvrblkk, imacman and 6 others like this.
  11. eatonpcat
    Should have bought an Enviro Willis, would have only needed one stove!! :whistle:
  12. Luneyburg
    Luneyburg
    Hills of Central Mass
    Have a Rutland on the side of the Harman and nothing on the cellar stove but after the cleaning on Friday had it cranked and was showing 550* . Even with two stoves in the leaky old farmhouse when it gets into the teens its time to crank them up ! 5 feed rate and 6 continuous burn I don't fuss with the T-stat it never stops running anyways once it gets cold.
    Cellar stove run on 4 outta 8 just enough to create a positive pressure down there so I ain't drawing cold air from stone foundation into the first floor .
  13. ivanhoe
    ivanhoe
    Northern Ontario
    You haven't OAK the Harman? It would help on the leakage upstairs:whistle:
  14. Luneyburg
    Luneyburg
    No Ivan no real way to get it to the outside without it being fuggly or messing with my hearth which is built on a brick arch downstairs in the basement that supports the entire chimney 4 floors. I could definitely rework it have the knowledge but not the time and it would cost some serious coin, otherwise it would run on the floor to the outside of the house which is about an 8' run. Stove in the basement has helped significantly with the drafting issue actually pulling cold air from the basement foundation because of the chimney effect created by the beast on the first floor. There is a lot I can do but time restraints with work rule right now.
    Forgot to add pics as requested so here they are , Rutland thermometer climbing back up and when you crank these p68 all the way its quite impressive the amount of fire they generate. This is when you can truly see what these beast are capable of, unfortunately stove ran out of pellets last night and buggerd up the glass so pics are not so great . IMG_0403 (2).JPG IMG_0406.JPG IMG_0407 (1).JPG IMG_0408.JPG
  15. jtakeman
    :D
  16. bogieb
    And to add to Luneyburg 's explanation for using 2 stoves. I have OAKs on both stoves but the bedrooms have incredible pressure from cold air from the floors (over garage), 2 outside walls (both rooms) and the ceiling (not covered by plywood and/or wallboard - just ceiling tiles nailed to strapping and not all that tight). During the deep cold of winter I need the P43 to be on constantly to keep a positive pressure and repel cold air infiltration in those rooms.
    If I ever win Powerball I can build a detached garage and turn the under-house garage into an extension of the basement. Then the P61a can keep the floors of the bedrooms warm - then maybe the P43 could be kept on thermostat all season long.
    Luneyburg, CleanFire, don2222 and 7 others like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    :thumbs:
    CleanFire, bogieb, ivanhoe and 3 others like this.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    If I ever hit the Powerball, I won't need a stove anymore!!! I'm going somewhere warm!!! :D
    CleanFire, will711, Rich250 and 9 others like this.
  19. ChandlerR
    ChandlerR
    Seacoast NH
    Got my new controller. It's a Eurotherm and is a different size so for now it's sitting nekkid on the stove. The top temp is the air coming out of the heat exchanger. The stove is on setting #1. We'll see what it says when I get a chance to crank it. The bottom is just a random set point that I need to read the book and figure out how to make it go away.
    Luneyburg, CleanFire, ivanhoe and 6 others like this.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    Running Cubex HWD full rip with temps of 172*F at the distribution take-off. Furnace is still in tweaking phase. Glass is dirty if you haven't noticed:whistle:
