Covering your wood stacks?
Discussion in 'The Wood Pile' started by MikeyB, Apr 2, 2017.
  1. MikeyB
    MikeyB
    Long Island NY
    Do you guys cover your wood stacks at all? If so how?
    This morning I was checking out my stacks and after the all day wind driven rain we had this past Friday my tarps didn't do much more than get filthy and nasty.
    Today is a nice sunny day on Long Island so I decided to remove the tarps and come up with another way of covering the tops of my stacks.
    Was thinking of hitting the Home Depot later on to pick up a couple of lengths of vinyl soffit material and give that a try. I really don't like the look of tarps anymore, they seem to more work than anything else.
    Here's some pics of my stacks after the tarps were removed eariler.
    Hammy, Hellcat, Eric VW and 9 others like this.
  2. Marshel54
    Marshel54
    Do you intend to burn the wood this year yet?
    I leave the wood that I have cut and intend to burn for the coming season not covered. I feel the sun and wind lessen the seasoning time. I then tarp that wood in Sept. using the uglies as weights. I agree that the tarps are a pain.
    I am planning on building some racks similar to what you have and covering them metal roofing I have laying around.
    I have the most of 2017/18 wood cut already and have started on a 2/3 year plan. That wood is going to the barn along with faster drying wood for the remainder of next years burning. The racks that I intend to build will be used when I bring the wood up closer to the house for burning.
  3. MikeyB
    MikeyB
    Long Island NY
    All this split wood is from a Red Oak I had cut down in my yard this past Jauuary, not sure if it will be ready for the for the fire place by next winter 2018? Most likely ready for 2019 winter. I was thinking of some corrugated plastic/metal roofing material as well. My yard gets some pretty goo exposure from the sun so I'm hoping with the nice summer breezes it dries the wood faster than expected.
  4. FatBoy85
    FatBoy85
    Washington State
    Been covering mine for the rain a few times just try to uncover when the day is nice and its getting ample air. Wind is blowing right now and im redoing stacks on pallets now. My stacks are getting a bit weighed down even though they are drying. Wood isn't holding up well right now.
    Hammy, Eric VW, Horkn and 1 other person like this.
  5. papadave
    Possibly, but in my experience....not likely.
    Burnable? Probably, but you'll suffer doing so. Again, my experience from when I first started burning wet Oak.
    I had mine covered for over 3 years, then I got disgusted with that hot mess, and built a shed. Life is much gooder now, but I only load the shed with wood that's been out in the elements for at least 2 years (not using too much Oak anymore).
  6. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    I started with tarps, but you're right, they seem more work than anything. I use them as a last resort. I have my stacks covered either with tin siding or 4x8 junk plywood. Some of my wood isn't covered at all, but it's slated for 2 years from now, so it doesn't matter. Or I didn't get to it yet.:D
    A wood shed makes life easy, and even if your wood is "not quite there", 4 months in a hot shed it sure will be.
    Hammy, Log Dog III, Eric VW and 4 others like this.
  7. Horkn
    A wood shed is the cure all. Tarps suck. They fall apart and look like crap.
    Rubber roofing, EPDM works much better.
    Hammy, Log Dog III, Eric VW and 7 others like this.
  8. bogydave
    If the stack is too a stay there stacked until it's burned,
    Top cover is important in most areas
    I stack the first year in a double row with space inbetween
    Then to the shed for 2 years
    My problem is drifting snow thru winter
  9. Ashwatcher
    Ashwatcher
    West By God Viginia
    My remote stacks, double row on pallets and single row on the rail rack are covered in galvanized corrugated metal roofing and rubber roofing, and used in both materials is not too difficult to find-tarps are a waste of time and money, IMO...as others have said-leave uncovered for a yr, covering in the late fall the following season and to the shed in the spring...rinse, repeat, re-load...
  10. bushpilot
    bushpilot
    Eastern Washington
    I cover mine with split firewood.:whistle:
    Hammy, Log Dog III, bang and 6 others like this.
  11. HDRock
    Doesn't matter what you cover with, the sides will get a little wet from wind driven rain even in a wood shed.
  12. papadave
    Which dries faster than I can eat a bowl of ice cream.:rofl: :lol::dex:
    Stinny, Hammy, Eric VW and 8 others like this.
  13. MikeyB
    MikeyB
    Long Island NY
    Thanks for the info guys, I think I'm going to leave the racks uncovered for now until next winter. I currently have the majority of the top rows with the bark facing upward, not sure if that makes any difference?
    With that wind driven rain the ends got soaked anyway.
  14. FatBoy85
    FatBoy85
    Washington State
    Yes!!!
    Hammy, Eric VW and Horkn like this.
  15. FatBoy85
    FatBoy85
    Washington State
    With the weather warming up, its not going to matter much unless your stacks are under trees and dont get a lot of air. I swear i see so many people put their wood under a tree and not cover it, well
    Branches are just dripping with rain after a good bunch of weeks. I made that mistake and it ruined a good pile of wood. You'd be just trapping moisture with a tarp likely.
  16. TurboDiesel
    We cover in Pa.
    We use reclaimed roofing rubber.
  17. leoht
    leoht
    Victoria. Australia. Earth.
    I use the plastic liners from my IBC totes to cover my wood.
    Stinny, Hammy, akennyd and 23 others like this.
  18. Ctwoodtick
    Ctwoodtick
    Southeast ct
    If you top cover with metal roofing or similar, find a way that you can block the sharp edges so to avoid getting cut by them.
  19. yooperdave
    This would work! :cool:
    Hammy, milleo, TurboDiesel and 6 others like this.
  20. Horkn
    Duct tape. With extra banjos.
    Hammy, Eric VW, Ashwatcher and 2 others like this.
