Corrosion hole in BlazeKing, KEJ1107
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, May 9, 2018.
  1. bogydave
    Was having trouble with the stove burning hot
    Cat chamber/bypass area glowing red.
    with thermostat on low.
    Was kinda scary that I couldn't turn to low & cool it down.
    Found a hole in the back, under the fan channel.
    Explains why it was worse with the fan running,
    forced air kiln. :eek:
  2. bogydave
    My fix to get me thru the burn season.
    Drilled holes thru 2 pieces of flat stock,
    Stove didn't need much drilling.
    sandwiched
    Gasket on outside piece
    Va Homesteader, Camber, Maina and 8 others like this.
  3. bogydave
    PS
    The other corner has pretty thin metal now too.
    Its under the fan chamber,
    I think the cool air hitting the back of the stove creates a great spot for creosote to form.
    Creosote is corrosive & the back of the stove is pretty thin metal.
    Was new 11-18-09 so it lasted 8 -1/2 years.
    Not sure how long a stove should last, ??
    Camber, Maina, FatBoy85 and 4 others like this.
  4. moresnow
    moresnow
    Interesting. Year of Mfg. ?
  5. bogydave
    Cant see a data plate.
    Guess 2008 ?
    Ser # 35306
    Camber, Maina, FatBoy85 and 1 other person like this.
  6. MikeInMa
    Hole in fire box - bad
    Fix - good
    Camber, Maina, FatBoy85 and 2 others like this.
  7. fox9988
    fox9988
    NW Arkansas 72717
    8 1/2 years the way you run it isn’t too bad. The equivalent of 30-40 years probably for most folks. How many cords been through it?
    Maina and Backwoods Savage like this.
  8. bogydave
    Guessing 45 - 50 cord
    Burning 7-8 months per year
  9. sam s
    sam s
    Minnesota
    I know you burn a lot more than most of us here. I would think the stove should give you at least 15 years.
    Camber, Maina and Backwoods Savage like this.
  10. TurboDiesel
    Seems for the money you should get more years of service.
    Did you contact BlazeKing?
    bobdog2o02, Maina, papadave and 2 others like this.
  11. woody5506
    woody5506
    Upstate NY
    Definitely contact them and see what they have to say. From what I've seen, Blaze King customer service is pretty great.
  12. bogydave
    Yes
    Contacted BK.
    They offered to send a new back plate.
    That will need welded in
    Old one will need cut out
    Haven’t check with local weld shops for
    cost estimates .
    I’m not able to get stove out of basement, will need help there . Then take to a shop.
    Concerned that it overheated other parts of the stove that in a couple years other parts may be damaged
    could be warped &/or may fail
    I mean it was glowing red.
    I couldn’t cool it down. (Didn’t know I had a hole under the fan assembly causing it )
    What if the side walls , bottom, or behind the fire brick are corroding , damaged.
    The BK guy said annually I should remove the fire brick , clean & inspect for damage. (Like maybe they know there’s damage under the brick too?? ) That kinda gave me pause .
    Also implied I’m burning “wet wood”
    & i’m not burning proper , causing the creosote problem.
    Plan to get through burn season, then go talk to
    the local BK dealer , see what he says.
    Maybe get a good price break on a replacement new stove??
    Camber, Maina, FatBoy85 and 3 others like this.
  13. TurboDiesel
    Yikes! I have so many thoughts here.
    I hope so, but...
    for some reason, I don't see this happening...
    for reasons you mentioned above.
    You fault
    wet wood
    bad burning practices
    lack of maintenance ....
    They've already covered their bases...
    even offered you a "replacement part"...
    (that will cost you hundreds of $$$ to have welded in)
    Either way you have to take the stove out of your basement and get a new/repaired one in.
    IMO, If you like their stoves, buy a new one
    ... (and destroy the old one)
    Camber, Maina, fox9988 and 2 others like this.
  14. Backwoods Savage
    Dave, that is always scary having a stove burn out like that and I always recommend replacing the stove ASAP. However, I have assisted a few folks when that happens mid-winter to help them get through before replacing the stove. One fellow didn't replace for another 3 years! Basically we did sort of like you did with the addition of some JB Weld too and gasketing material. It worked well, but I still say replace if you can.
    Have you considered an Ideal Steel?
    Camber and Maina like this.
  15. TurboDiesel
    Shipping may be a bit costly but it would be a good choice
    Camber and Backwoods Savage like this.
  16. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    guess i better check mine....i think its 7 yr old
  17. bogydave
    Gonna shop around.
    Stainless steel might handle AK birch
    better.
  18. Backwoods Savage
    Why do you think AK birch would be a problem with any steel stove?
    There is also the Progress Hybrid to consider. Soapstone and cast.
    Maina and BCB like this.
  19. Locust Post
    I think FHC would come in handy if you needed to disprove this. You have enough posts talking about your wood seasoning and burn patterns.
    Camber, Maina, papadave and 1 other person like this.
  20. Locust Post
    Here is a few thought that cross my mind. I would get the bricks out when you are done burning and get a welding pick hammer or even a ballpeen hammer and do some pounding around on the different panels. It may just play out that the back panel is the only weak spot. If that is the case I would check around for a welder to come to you and do the repair right in the basement. You have good access down the wood shoot for welding cables and weld smoke exhaust. May find one that has a plasma cutter too.
    If the stove has other weak panels then say goodbye to an old friend.
    Camber, stuckinthemuck, Maina and 6 others like this.
