corn, what do i need to know?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ivanhoe, Apr 6, 2015.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    I going to check out some farmer's corn for heating. I know the humidity & cleanliness is important. What I'm asking is what to look for when doing a visual inspection. I can get a 1/2 ton & 1 ton bag loads. Proper storage do's & don't's info. Unloading contents into pails as I need them from the big bulk bags. Pest control and whatever else to know on corn handling & storage is needed ASAP as I'm getting ready for the spring purchase. I plan of mixing with pellets for complete burn and easier relighting. I wish Iburncorn.com website was still going strong.
  2. JRSDWS
    JRSDWS
    Central Illinois
    Dryness and cleanliness of corn are the top concerns. The dryer it is, the hotter it will burn. Red dog can cause you some serious heartache. Otherwise, nothing much to worry about as far as the corn itself.
    Pest control will be difficult in bulk bags, unless you can put the bulk bags into something mouse proof. I bought my corn from the elevator last fall and kept it in a gravity wagon which was parked in a shed at the neighbor's. There was lots of cob pieces that we had to just be careful about catching. Red dog wasn't too bad. I think they're system cleans most of that out. I have 10 of the food grade 55 gallon plastic barrels that I stored and used from. I think I have enough left to fill them all again for summer storage.
    Try your stove with various mixtures of pellets. Something around a 30% pellet ratio makes the klinker easier for me to manage.
    The only other thing I can think of is to be certain all of your venting is rated for corn.
  3. eatonpcat
    I really like the steam in a bag corn...couple minutes in the microwave, add butter and boy is it tastey!!
  4. ivanhoe
    ivanhoe
    Northern Ontario
    will711 and Horkn like this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    Can you explain Red dog? I like the idea of the plastic 55 gallon drums, mouse resistant:thumbs:
  6. JRSDWS
    JRSDWS
    Central Illinois
    Sorry that might be a regional thing....we call the red hulls or chaff (sp) that flys around when combining or moving harvested corn.
    DexterDay and ivanhoe like this.
  7. smoke show
    smoke show
    Pittsfield, Wi
    Aka redwings.
  8. imacman
    imacman
    Denver, NC
    As mentioned above, proper moisture level (no more than 15.5%), ability to get cobs/husk pieces out, air tight storage.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Is there a way to check humidity on the fly?
  10. mithesaint
    mithesaint
    NW Ohio
    Do you have a grain elevator locally? They'll usually check moisture levels for free. Some farmers will also have moisture testers. My Dad used to, but his new combine has all that information automatically so he got rid of the tester. Look at the manual for your furnace. My St. Croix specifies less than 15% moisture corn, and that's exactly what I had, and it burned just fine. My Englander wants 12% corn, and wasn't particularly happy burning the 15% corn. The corn is probably going to be in the 15% range anyway. It doesn't store well at higher moisture levels, and it costs too much money to dry it lower than 15%.
    I stored my corn in 55 gallon drums as well. It worked pretty well. I had to build a corn cleaner because I had a ton of fines that were causing problems. After that it worked well. Corn burned faster than pellets in my furnace, but it also produced more heat. The corn was actually easier to burn and didn't make as much mess as the pellets did in the furnace. The freestander was the opposite.
    I bought a hopper wagon at a local auction this spring, and I'm going to try tarping the wagon and parking it outside for this year. I had to borrow a wagon last year, and it was a bit of a pain.
    Good luck. I really liked how the corn burning went, but I need to find a better way to move it. I'm looking into setup's that allow use of a shop vac to move corn. I'll get back to you on that one.
  11. ivanhoe
    ivanhoe
    Northern Ontario
    Moving the corn from bulk bags could be a challenge. Will have to make a hoist attachment and a control valve to facilitate the filling of plastic barrels. Furnace requires 15% or less humidity of corn. I foresee a cleaner is going to be a must have item.
  12. jtakeman
    Check out the corn vac system. You can move them and clean at the same time.
    http://www.cornvac.com/
    eatonpcat and ivanhoe like this.
  13. normanscag
    normanscag
    ohio
    Are you able to store corn in a old deep freezer in your home, without the mice issue
    ivanhoe likes this.
  14. eatonpcat
    I'm sure...but how much can it hold??
    ivanhoe likes this.
  15. mithesaint
    mithesaint
    NW Ohio
    Not to thread hijack (BEER!!!), but has anyone heard anything about these systems? I was looking at the cleaner/bulk storage unit, but I'm having a hard time seeing how their plans and hardware for the storage unit are worth the extra $100. How hard is it to make an airtight box??
    jtakeman and ivanhoe like this.
  16. smoke show
    smoke show
    Pittsfield, Wi
    Now that iburncorn.com no longer exists I'm not sure this will be much help.... Try googling kan_burn.
    ivanhoe likes this.
  17. jtakeman
    Did someone say Beer? Smoke, How'd ya miss that one! :p
    I have a kan burn(sifter) Its OK, But dry corn will be a bit dusty. The cornvac will also remove the dust. Another way is a simple vac sifter/cleaner you make out of pvc pipe. There are some a vid's on youtube.
    There's a thread here on a vac cleaner the members have made to clean pellets. I have CRS and can't seem to find it!! :doh:
    ivanhoe likes this.
  18. smoke show
    smoke show
    Pittsfield, Wi
    Jay I think you're confusing the kan_burn with something else.
    ivanhoe and jtakeman like this.
  19. jtakeman
    Oops! :doh: I found my sifter screen while searching can burns. So thats what dumb azz me though I had!! :p
    Heres and example of a can burn vac system. Notice the wire on the pvc. Its for static as it build easy in the pipe and you'll get a good whack off it if you don't ground the piping. FYI
    ivanhoe and smoke show like this.
  20. imacman
    imacman
    Denver, NC
    wildwest and ivanhoe like this.
