Converting To Pellet Stove
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by KatwillNY, Dec 6, 2016.
  1. KatwillNY
    KatwillNY
    After many years of burning wood, I am jumping ship and converting my Englander NC-30 to a
    Summers Heat 55-SHP10L. Got it for about 50% off at Lowes (returned due to a loud fan which Lowes replaced). I am thinking of using the same pipe as i was using for my wood, just getting a reducer. Has anyone does this and what has been your experience?
    don2222, wildwest, Russell and 7 others like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    I have a friend who did that. Works fine.
    Russell, eatonpcat, CleanFire and 4 others like this.
  3. Backwoods Savage
    Kat, when posting about the pellet stove you might want to consider posting in the pellet forum.
  4. jtakeman
    Moving it over to the pellet section...........
    Russell, CleanFire, ivanhoe and 3 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    Hopefully it's a smooth transition for you.
    CleanFire, slvrblkk and ivanhoe like this.
  6. jtakeman
    I think imacman installed his Timberheat the same way. Hey Pete where ya at.
  7. badbob
    badbob
    Some double wall wood stove pipe is certified for pellet,but,seeing a hand damper looks like single wall,so then should be pellet pipe all the way to wall thimble,as stove has forced draft.
    Russell, CleanFire, slvrblkk and 4 others like this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    My Accentra is setup that way. No problem with draft. Will send pic later.
    Russell, CleanFire, slvrblkk and 2 others like this.
  9. Lousyweather
    Lousyweather
    not being a nitpicker, but you're using an increaser......never decrease flue size....code violation! Also, don't use the hand dampers if youre running the pellet stove (not sure where you are making the changeover)
  10. imacman
    imacman
    Denver, NC
    Yep, that's what I did. Here's the pic. I got the adapters from Eric at Kinsman Stoves.......he was the only person who could decipher the pipe I had, and come up with all the correct parts.
    And yes, mine was all double wall pipe. The Astoria in the pic was 4" outlet, and later when I switched to the 10-CPM, it was only a 3" outlet.....a step-up appliance adapter was used there. Both stoves ran great with this set-up.
    Russell, CleanFire, will711 and 6 others like this.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Pete...do you still have that tin container next to the stove? I love that thing.
  12. KatwillNY
    KatwillNY
    The hand damper along with the entire pipe going up to the thimbal is being replaced. thanks for the feedback.
    bogieb, imacman, CleanFire and 3 others like this.
  13. ttdberg
    ttdberg Pellet Pig
    CT
    The P43 here is vented this way and it works like a charm.
    imacman, CleanFire, jtakeman and 3 others like this.
  14. ivanhoe
    ivanhoe
    Northern Ontario
    I see you have obtained your woodstove pipe thimble adapter already so you should be ready to hook it up any time soon. Don't forgot the 120v surge protector.
    imacman, CleanFire, jtakeman and 2 others like this.
  15. KatwillNY
    KatwillNY
  16. ivanhoe
    ivanhoe
    Northern Ontario
    imacman, will711, ttdberg and 2 others like this.
  17. will711
    will711
    Pocono Mts.
    Looks like mine 4" into 6" SS lined masonary flue that the wood burner was hooked into
    imacman, slvrblkk, CleanFire and 3 others like this.
  18. ivanhoe
    ivanhoe
    Northern Ontario
    Selkirk D-T?
    slvrblkk, CleanFire and IHATEPROPANE like this.
  19. will711
    will711
    Pocono Mts.
    No Pellet vent Pro.
    imacman, ivanhoe, CleanFire and 2 others like this.
  20. slvrblkk
    slvrblkk
    Northampton, PA
    :vulture:
    ivanhoe, CleanFire, jtakeman and 2 others like this.
