coldest ever
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Feb 14, 2016.
  1. BHags
    BHags
    Massachusetts
    It's 5:30 am here in Massachusetts. It's -11 degrees. -11 friggin degrees. My 9 year old Hastings, set on level two, (out of five), in my cellar, held my three bedroom ranch at 60 degrees overnight. That's pretty good if you ask me! Now that I'm up, that baby's going to be on four for a little while!
    Bags, thewoodlands, Russell and 7 others like this.
  2. millertime
    millertime
    upstate new york
    -17 here right now on the NE tip of New York. Stove is deffinately getting a work out.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    Showing -39*C as we speak. Waiting for it to drop some more when the sun comes up. My temps on the bottom of my page is off to my actuals:doh: The furnace is keeping up:yes:
    Russell, imacman, bogieb and 4 others like this.
  4. Wilbur Feral
    Wilbur Feral
    Eastern PA
    A balmy 5 degrees just outside Philly this morning. Santa Fe has the basement office at 71, while MVAE has family room at about 73, but it's got a bunch of windows and skylights. Heat pump came on but very little aux heat. Not a bad showing!
    Russell, BHags, ivanhoe and 4 others like this.
  5. Ambient
    Ambient
    Northern New York
    -25* here when I got up this morning.It's supposed to have a 13 mph wind, I haven't bother to go out and verify that.
    Russell, BHags, ivanhoe and 2 others like this.
  6. billporterfield
    billporterfield
    Northeast Wisconsin
    -20F, Northeast Wisconsin, Marinette County
    Russell, BHags, ivanhoe and 1 other person like this.
  7. Smokinpiney
    Smokinpiney
    "South" Jersey
    Dang that'spretty good BHags. It's right around 0° outside right now. Kicked her up to 5 for about an hr. :fire:
  8. ttdberg
    ttdberg Pellet Pig
    CT
    -13 here this morning. That's close to as cold as we've ever seen in this place. Went to bed with the P43 set at heat setting 2 with the room at 70 degrees. Woke up to find the room at 65 degrees, which is the oil burner's set point. Bumped the heat setting up to 3 and 30 mins later the room was 69 degrees.
    Russell, BHags, ivanhoe and 3 others like this.
  9. bogieb
    -21* when I got up this morning. The coldest I've seen since moving here. Have had plenty of -18's in 2014 & 2015. Had to bump up the feed rate on my stoves also this morning. Oh look, it is 74* in the office, time to lower the feed rate some more :D
    Russell, ttdberg, BHags and 3 others like this.
  10. subsailor
    subsailor
    Winthrop, Maine
    My stove was running hotter than it ever has last night. I was on heat level 4.5 with Blazers and Olympus in the hopper. Thermometer on the side of the stove was reading 500. Every time I walked by it I would break out in a sweat.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    :dennis:
    Russell, ivanhoe, BHags and 4 others like this.
  12. Keep-in Warm
    Keep-in Warm
    I actually turned down the pellet stove abit and fired up the baseboard heat for the first time this year. Was afraid the thermguard zone protectors wouldn't be enough.
    Russell, will711, ivanhoe and 4 others like this.
  13. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    Maybe this will be the last cold snap. Looking at the weather, next Saturday is showing in the 50's, which is hard to believe I know.
    Bags, Russell, bobdog2o02 and 3 others like this.
  14. ttdberg
    ttdberg Pellet Pig
    CT
    Supposed to be 53 here on Tuesday!
    savemoney, imacman, Russell and 4 others like this.
  15. BHags
    BHags
    Massachusetts
    We might get a warm day or two, but it aint over yet! Still two tons (out of four) in my cellar to burn. I've never had more than 1/2 ton left over, one year I was down to five bags!
    imacman, Russell, ivanhoe and 2 others like this.
  16. bogieb
    How often and for how long do you have the Thermguard set for? I used to be nervous too, but I go 3x per day at 8 minutes a shot and it is fine. Course the only reason I have it is because I have pipes that run thru the garage. Otherwise, I think everything would be fine without since my basement is now heated and I've put in new insulation in all but one wall (and that is just above the basement stove, so should be warm enough anyway). If you have poor insulation, you might want to set it for 4-6 times per day.
    Russell and ivanhoe like this.
  17. Husqvarna89
    Husqvarna89
    North Eastern P.A.
    Its been 20 degrees all day here so far in gettysburg pa last night it dropped to about 0 kept the house warm with 3 electric heaters which held it round a comfy 60+ i cant complain now tonight the woodstove will be lit for sure
    BHags, Russell, ttdberg and 2 others like this.
  18. will711
    will711
    Pocono Mts.
    Welcome to the show Husky89 Why you not have that wood stove fired up yesterday ?? heating with electric :hair::hair: expensive
    savemoney, ivanhoe, BHags and 4 others like this.
  19. ttdberg
    ttdberg Pellet Pig
    CT
    Did you guys buy your thermguards direct from Bear Mountain? The hot water baseboard pipes for the master bedroom run through the garage and sometimes they freeze in the winter, then it's a big (huge) pain to get them thawed. Would like to get one of those gadgets to circulate the water at regular intervals so we don't have to worry about it.
  20. Husqvarna89
    Husqvarna89
    North Eastern P.A.
    Hey will lol thanks man we were out late last night and when we did get home house was allready warm so kinda got lazy and left it go just on electric so yah my bill wil be quite higher this month but will light for sure tonight lol thanks
    ivanhoe, Russell, will711 and 2 others like this.
