Cold weather Bar and Chain oil?
Discussion in 'Chainsaws and Power Equipment' started by Sinngetreu, Dec 12, 2020.
  1. Sinngetreu
    Sinngetreu
    North Central Iowa
    I've been running Husqvarna's All-season bar and chain oil when I noticed on the back that they do not recommend it being ran below 32 degrees (F). So much for all season.
    What do you guys use in freezing temps? I know that when the saw warms up, it probably isn't such a problem, but I use my saw intermittently fairly often.
  2. Creekin
    Creekin
    Manitoba
    I use whatever winter bar oil i find, no particular brand, but i will cut in -35°c
    Tried summer/allseason and didn't pour, kinda oozed out
    Sinngetreu likes this.
  3. Rope
    Rope
    Alaska
    Arctic (blue jug) Sthil bar oil. It is pourable as cold as -55* that I have used it in. When I am at home I use the cheap summer oil, time of year doesn't matter. If I can keep the oil and saw warm prior to use I don't see why it matters. When I am away from home cutting and its colder than 32*, I will use blue jug.
    OldJack, Aje1967, Farmchuck and 3 others like this.
  4. Firewood Bandit
    Firewood Bandit
    I like Essence Winter blend a lot.
    If you have Summer oil and it is too thick, add a little diesel fuel to it.
  5. Sinngetreu
    Sinngetreu
    North Central Iowa
    Is there a certain amount for a quart size or put in just enough to get it to pour at low temps?
    Firewood Bandit likes this.
  6. Firewood Bandit
    Firewood Bandit
    Well it's not like baking a cake.:rofl: :lol::whistle:
    Sorry couldn't resist.
    Seriously, I don't think thick oil is really a big thing other than the inconvenience of pouring. Once the saw is warm, the exhaust is right above the oil tank and metal chassis saws heat the oil up by the time you go back to work.
    walt and Sinngetreu like this.
  7. Sinngetreu
    Sinngetreu
    North Central Iowa
    Well, how else am I supposed to overthink things if I don't ask dumb questions?! :D:wacky:
    I usually take the same stance, but I've been questioning everything since seeing the bottle. It takes a bit to weed out the difference between actual requirements and statements to avoid liability.
  8. Rope
    Rope
    Alaska
    I have a few buddies that run the summer oil/diesel mix they run 50/50.
    Sinngetreu and Firewood Bandit like this.
