Cold Start
Discussion in 'Chainsaws and Power Equipment' started by HighCountry, Jun 8, 2016.
  1. HighCountry
    HighCountry
    New Mexico
    How many of you use the cold starting procedures for your saws, outside of winter conditions? I tried starting my new (to me) saw with the cold start procedure last night and I am 99% sure that I flooded it, immediately. Just curious if I should only need to use cold starting during the winter.
  2. Oldman47
    Oldman47
    Illinois
    On my Husky 555 I use the cold start year around but don't insist on much of a first burp. If it makes any noise it is time to take the choke off. If I have used the saw in the last hour or so I will try it with just the fast idle because I don't consider it cold.
    Mitch Newton, Horkn, Eric VW and 5 others like this.
  3. TurboDiesel
    My BR600 will flood pretty easy. If it was running today you probably wont need to choke it.
    If I smell gas when pulling the cord, its WOT time. then pull till it starts.:yes:
    Horkn, Eric VW, cnice_37 and 3 others like this.
  4. Shawn Curry
    Shawn Curry
    Western NY
    That will happen with a new saw until you get used to what it wants. I don't do anything different in cold vs warm weather. But, with my bigger saws, I have to be careful not to pull the rope too many times with the choke on, whether I hear a "burp" or not. I usually don't hear it on the 880, but 2 pulls on full choke is plenty. After that, ill switch to high idle and it will usually start on the next pull.
    Horkn, Eric VW, pantelis and 5 others like this.
  5. TurboDiesel
    Same here.
    But I'll try the 2 pull thing next time on a warm day. :yes:
    Horkn, Eric VW, HighCountry and 2 others like this.
  6. bogydave
    +1
    IMO, cold start is more a fuel issue than a temperature issue
    HDRock, Eric VW, HighCountry and 2 others like this.
  7. lukem
    Mtronic. ...just push the lever down and pull the rope.:D
  8. Barcroftb
    Barcroftb
    The Mitten
    HighCountry for my 7910 it's 1 pull full choke wheather it pops or not then no choke and usually 2 pulls starts it. If I don't do it that way it floods and it's WOT and pull til it starts. DexterDay turned me on to that procedure after telling me his 6400 was like that. I bet your 6421 is the same.:yes:
    Nixon, pantelis, DexterDay and 3 others like this.
  9. HighCountry
    HighCountry
    New Mexico
    It had already been started that day, so I probably should not have pulled more than once with the choke. I just got excited and wanted to hear her purrrrrrrr, but then I smelled the fuel and knew I was an idiot. Hopefully, I get to spend a little more time with her after work tonight. Got home later than expected yesterday and didn't get more than 10 minutes to mess around. Not nearly enough time!
  10. cnice_37
    cnice_37
    I always choke them. Some saws are easier to flood, you just have to find that harmony in the saw-niverse and go with it.
    Be the saw..... nananananananananananana
    Eric VW, Oldman47 and HighCountry like this.
  11. HighCountry
    HighCountry
    New Mexico
    I will just leave these here.
  12. TurboDiesel
    36 years and still funny!:rofl: :lol:
    unclefess, Eric VW, LongShot and 2 others like this.
  13. HDRock
    Are you using the decompression valve?
    My 445 starts better without using it, I don't think it's really needed on that saw all but it does start better without using
    HighCountry likes this.
  14. RCBS
    RCBS
    Over here
    I have a rag tag band of mixed saws and they are all just a little different. Echo is cold blooded and will stall after first starting if you try to goose it...it likes to idle for 10-15 seconds then will take off. 550 likes by the book cold start procedure, unless ran in last half hour. My 2166 will flood on me once in a while. Choke till burps, then 2-3 pulls on high idle and usually it stirs to life. My old 350 likes choke and high idle and burps on second pull like clockwork. Choke off and one pull to running.
    Saws are all a little different, but that's what makes them fun!
  15. pantelis
    pantelis
    Europe
    This is why i use only electrical saws , no hot , no cold , no flooded , no decomps :D
    cnice_37, eatonpcat, CoreyB and 3 others like this.
  16. Barcroftb
    Barcroftb
    The Mitten
    Watchu talkin bout willis! Did you get any landscaping done last week? Stones? Garden?:whistle:
    Eric VW and pantelis like this.
  17. tamarack
    tamarack
    paulina oregon
    372 xtorque full choke till it pops then no choke 2 pulls. 550 seems to roar to life on 2 to 4 pulls with choke on. 266 is full choke 5 pulls and she's running.
    Eric VW and HighCountry like this.
  18. HDRock
    When it doesn't start after pulling on it 10 or 20 times and you pulled the plug and it's dry, maybe there's no fuel in the tank :whistle::headbang:
    CTYank, Eric VW, MasterMech and 5 others like this.
  19. DexterDay
    DexterDay Administrator
    Northeast Oh
    Yes sir.. 1 pull on choke. Then push it in to high idle. 2-3 more pulls and you're good to go :thumbs: Don't wait for a pop on that saw. My Solo was the same way. More than one pull on full choke and it would flood
    Otherwise, you'll need to hold the throttle wide open and pull on it 30 times. :(
    Nixon, Eric VW, HighCountry and 2 others like this.
  20. HDRock
    My solution for that, pull the plug dry it out,, less work :saw:
