Coal burn down
Discussion in 'The Wood Pile' started by Chvymn99, Dec 6, 2013.
  1. Chvymn99
    Going to try to burn down a bit of coals this morning, without using prime wood. But the NC13 been just chugging away. When I woke up at 4 am it was 1/2 full of coals. Been trying to squeak out the heat from those coals.
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I get a ton of coals when it's really cold out. Sometimes I have to clean them out to make room for more wood. :(
    Chvymn99 likes this.
  3. blujacket
    blujacket
    Kettering, OH
    I pull mine to the front and open the air all the way. They burn down pretty fast.
    Trilifter7, gmule and Loon like this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm not sure I would ever clean them out to make room. I usually wait til they burn down enough to make a flat bed and then reload. My cycle times would decrease if I handled the larger coals too early.
    Chvymn99 and blujacket like this.
  5. Jack Straw
    Jack Straw
    The problem is I can't get enough heat out of them to warm up the house. This happens on very cold mornings. Maybe I am turning down the air too much at night? I get a bed of coals that are 8-10 inches and it can take several hours to burn down.
    clemsonfor, Mitch Newton and Chvymn99 like this.
  6. blujacket
    blujacket
    Kettering, OH
    Either cutting down the air too fast/much, or your wood isn't dry enough.
    milleo, NortheastAl and Chvymn99 like this.
  7. Chvymn99
    Pretty much my situation when the temps drop below 20 degrees for a extended time. But since I'm on vacation, I can baby her right now. I'm right now trying to figure out if I can switch out the 30 today or just weight til it warms back up a bit.
  8. Chvymn99
    My situation is just undersized stove in the temperatures that we are getting. If I wasnt around, I probably wouldn't have much a problem, but then again when I'm around I want a warm house.
  9. Jack Straw
    Jack Straw
    The wood is dry, I guess I'll try to keep the air open more.
  10. swags
    swags Moderator
    I had that problem last year with the stove and no back up heat. I would have to pull out some coals to get a reload in. Stove was just undersized for the house,
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    I'd say that if you have coals that large in the morning you do have the air turned down a bit too much. My next thought was stove size, but it seems with coals that size in the morning that it's a good size burner.
    what is your stove temp when you get to the stove first thing in the am?
  12. MrWhoopee
    MrWhoopee
    Shingletown, CA
    I keep hearing the Talking Heads:
    "Burnin' down the coals........"
  13. Backwoods Savage
    Next time when you get up during the night to pee, give the stove a bit more air. 8-10" is a lot of coals!!!!
    HDRock, papadave, blujacket and 2 others like this.
  14. bogydave
    +1
    May take a few times , pulling them to the front, but works good for me too.
    If I need more heat when burning down the coals, I add a split on top.
    Run on high.
    clemsonfor, HDRock, papadave and 2 others like this.
  15. Well Seasoned
    +2 with what bogy Dave explained. Adding a small split burns down coals faster that are raked forward and adds a bit of quick heat to the stove while doing so.
  16. Pallet Pete
    Pallet Pete Moderator
    Ovid
    We buy a couple bags of pellets each year and use them for 2 purposes. 1) it makes lighting much easier if you put them in the stove and then lay the lighter on top. HOT HOT HOT:cool: 2) if you pour a small amount on the coal bed after you rake it in front they tend to burn into the pile lighting it up and burning it down fast. It eliminates the coal bed fairly quick.
    Oldhippie, Chvymn99 and Jack Straw like this.
  17. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    He needs heat. Open up the air.
  18. Chvymn99
    That pile of coals, I finally got burned down by about 2 pm. I just kept raking it forward and putting small chunks of wood on top. For the most part it was suprising how long the heat kept decent while I was tending it.
    clemsonfor, JoeyD and papadave like this.
  19. bogydave
    Kinda like heating with charcoal.
    Surprising how much heat output you get.
    Backwoods Savage and Chvymn99 like this.
  20. JoeyD
    JoeyD
    When I get too may coals I rake them towards the front and lay a small spilt on top. It always seems to throw a lot of heat doing this. Sometimes I repeat, This seems to burn the coals down fast.
