Clutch..
Discussion in 'Chainsaws and Power Equipment' started by Chvymn99, Apr 27, 2017.
  1. Chvymn99
    So I've got to replace my slave cylinder on Ford Ranger. I'm getting my clutch and all that other stuff to go with it. Its been a few years since I've research Clutches. But I want to get a stiffer clutch than a stock one. I use my truck as a truck and pulling my tandem axle trailer, I know its there. I've been looking at the Centerforce clutches. I know that they have a good rep, but is there any other variety to look at? Am I going overboard with this type of clutch? Just curious.
    Eric VW, wildwest and Barcroftb like this.
  2. Boomstick
    Boomstick Banned
    Saratoga county ny
    South bend, valair to name a few others to look at.
    Not sure if you have a dual mass flywheel as a stocker(probably do), but switching will give a better feel and probably some vibration possible noise but will work better.
    Eric VW, Chvymn99 and wildwest like this.
  3. cwn877
    cwn877
    Central Pa
    Spec and luk make heavy duty clutches for rangers I believe. You might be going overboard but isn't that what it's all about. My neighbor has one he beats around everyday on his farm. It got to the point where if he parked on a slight grade the clutch wouldn't hold and the truck rolled away. Finally when it quite moving all together he bought a stock replacement clutch kit and resurfaced the flywheel and it's been going strong since. Just keep an eye on disc material as some are pretty aggressive and can be grabby or wear the flywheel and pressure plate if slipped.
  4. The Wood Wolverine
    I put a Centerforce in my import @ 60,000 and I'm at about 118 now. Highly recommend them.
    A little while back we put a Luk in the Jeep on a recommendation from the local trusted Jeep specialist (offroad 4x4 shop). I researched before pulling the trigger and they have a great reputation. If I had it to do over, I'd pick the same.
    Eric VW and Chvymn99 like this.
  5. mdavlee
    mdavlee
    Luk is oem for a lot of manufacturers.
  6. Chvymn99
    Did a little research last night.
    mdavlee - I did notice that Luk comes in various names.
    cwn877 - read a couple good things about the spec's.... but I've yet to find them on the larger seller site. May have to investigate further on it.
    Some of those other brands that were named I've never heard of, but availablity might be interesting. I was talking to my buddy, he suggested looking at maybe just rebuilding my old clutch. Then they can make it to my situation. Anybody heard of that?
    Eric VW likes this.
  7. cwn877
    cwn877
    Central Pa
    I never looked into buying a clutch from spec just heard good things about them sorry not much help there. In the past I have rebuilt clutches for construction and farming equipment with good results. I have never done one in an automobile guessing it's not as cost effective but you can make it what you want.
  8. brenndatomu
    Yup, sometimes that's your only choice when you need a clutch or brakes for some older vehicles...get 'em re-lined. Used to be more common than it is now I believe
  9. Chvymn99
    Well I splurged and went with CenterForce... so time will tell... how much muscle gain my left leg will be getting....:D
    The Wood Wolverine and Eric VW like this.
  10. The Wood Wolverine
    You won't regret it. If I recall correctly mine was 60% more clamp force but pedal feel was marginally more. It's been a while so don't quite me on that. I do still have the original box it came in so next time I'm in the garage I'll look (out of curiosity).
  11. Spencer
    Spencer
    Indiana
    Late to the party! I had a 87 mustang drag car and had a spec clutch in it. Held up to 10.5 slicks at the track, so it was pretty stout. Im sure the centerforce will give years of good service.
    Chvymn99 likes this.
  12. Chvymn99
    Well clutch is done. All went pretty story book like. The pilot bearing not so much... it was pretty much done... IMG_0808.JPG
    Here is what was left.... :confused:
    So we got it replaced in time. I did find out my left leg shortened up. Had to slide the seat up 2 notches.:D.. now that clutch is further down that it use to be.
    OhioStihl, Eric VW and brenndatomu like this.
  13. Eric VW
  14. brenndatomu
    Looks like ya got your moneys worth outta that one! :yes:
    Might even have left a few pieces of it in Backwoods Savage driveway! :startled:
  15. Chvymn99
    Yea, looking at it.... I got lucky... I'm sure it went out before the slave cylinder went out... The good Lord was looking over me on the trip I'd say...
    Eric VW, wildwest and brenndatomu like this.
  16. OhioStihl
    OhioStihl
    Southern Ohio
    My old truck needed a clutch and I put Centerforce in it. I don't remember if the clutch pedal feel was different or not. I ABUSED that truck and the clutch was never an issue. Enjoy your ride.
  17. Eric VW
    You ain't kiddin' :)
    brenndatomu and Chvymn99 like this.
