Cleaning stove glass with abrasives
Discussion in 'Modern EPA Stoves and Fireplaces' started by Steve, Nov 29, 2014.
  1. Steve
    Steve
    Stouffville, ON
    The smoked glass on my Jotul 602 was becoming a little smokier than I liked. I tried the wet paper towel dipped in ash trick, but it was as hazy as ever after repeated scrubbings. So I opted to get a bit more aggressive. I have polished aluminum to a shiny surface, so why wouldn't the same technique work on glass?
    Here is the before shot:
    The after:
    I used a palm sander with the plate of glass resting on a scrap of Styro SM:
    The sandpaper:
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    I can't see why wet sanding wouldn't hurt, I don't think it would look any worse than when you started.
    Starting with a lower grit and working yourself up to a super high grit may get you some clear glass again.
    I've never had that problem before so I really can't help much, sry
  3. Steve
    Steve
    Stouffville, ON
    I was wondering too if I should with a coarser grit. What would you suggest?
    I have a belt sander
  4. yooperdave
    I can only think of screaming! NO! NO! NO! power sanding?
    The only things I have ever used is newspaper, ashes, and a little water (very very little)
    Did you glass come clean?
    My BIL will still only buy wood this year to burn this year. The glass door has little resemblance to glass, more so it resembles the black steel of the stove! All I used one day were the above mentioned ingredients (oh yeah, elbow grease and persistence) and had the glass back to life! Only downfall is, he had to listen to me and the benefits of drying wood in advance. My lecture failed miserably!
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    I use this stuff for any creosote that gets on my ceramic glass window and it works well with little effort:
    http://www.lifeandhome.com/imperial-kk0290-glass-cleaner-22oz.html?gclid=CPH245aAocICFUMV7AodhiIAQg
    Can't recall where I bought it but it was inexpensive..
    Ray
  6. Steve
    Steve
    Stouffville, ON
    Well, like I said the wetted ash trick didn't work. It's a palm sander and 1000 grit. That is so fine that it will actually leave a dull gloss on whatever it is you're sanding. If I were polishing aluminum to a mirror like finish, this would be the second last step.
  7. Steve
    Steve
    Stouffville, ON
    raybonz likes this.
  8. yooperdave
    Kinda thought that out myself with the pic of you holding up the glass!
  9. papadave
    Gark and raybonz like this.
  10. pappy88
    pappy88
    Missouri
    try oven cleaner.
  11. MightyWhitey
    MightyWhitey
    Try burning dry wood.
    Then black glass doesn't happen.
  12. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    That's not entirely accurate.
  13. Well Seasoned
    Keep us updated, but I believe jotul has a special coating on the ceramic window. If I remember correctly, the window needs to be placed in exactly the same way as removed.
  14. Steve
    Steve
    Stouffville, ON
    My wood is as dry as it comes. I only burn hot fires and my flue is double walled, straight vertical, 20 feet. Excellent draft. Look closer at the photos. The glass isn't black, it is somehow etched.
  15. Well Seasoned
    It tends to become etched after being dirty for awhile. Jotuls have large windows, and during a low burn can become stained, especially on the lower corners. Im burning 3 yr oak and the corners stain.
    Pallet Pete and raybonz like this.
  16. Locust Post
    I'd guess your best bet is going to be throw that glass in the hollar and get a new piece. Sand paper on glass does not usually work out real well in my experience because it's so hard. I've sanded and buffed many vehicles over the years but clearcoat is quite different than glass. If you are dead set on this avenue you could get some jewelers rouge and try that after your done with the sandpaper.
  17. Murph
    Murph
    Try some rubbing compound. or some Mequires #7
    Sam likes this.
  18. splitoak
    splitoak
    jefferson co wv
    Its not technicaly glass..its pyroceram.:whistle:..i was told to use nothing but a wash cloth and ashes..it works well fer me:thumbs:
  19. Norky
    Norky
    Every morning, before I load the stove, I rub down the inside of the glass with 0000 steel wool whether it needs it or not.
    Glass stays clean and don't get buildup.
    Chestnut, Fanatical1 and macpolski like this.
  20. KaptJaq
    KaptJaq
    Long Island, NY
    Once he used the palm sander and the 1000 grit wet he probably does not have to worry about the coating...
    KaptJaq
    EDIT: the infrared coating is on the outside of the glass in the newer stoves. Cleaning the inside with abrasives shouldn't affect it. Glass should be put back on the way it came out...
    Well Seasoned and splitoak like this.
