Class A temp readings
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Jan 2, 2017.
  1. Well Seasoned
    Stovetop temp: 585°
    Single wall pipe: 450ish
    __________________________________
    Class A....
    At the roof penetration 0°
    Midway up - 14°
    Top - 20°
    Inside cap 67°
    Outside air temp 15.3°
    Interesting :)
  2. Backwoods Savage
    Flue temperature with a probe?
    Well Seasoned likes this.
  3. MightyWhitey
    MightyWhitey
    I'm confused here.
    Well Seasoned and saskwoodburner like this.
  4. yooperdave
    I'm thinking he is measuring the outside of the class A pipe.
    Don't understand how the pipe can read colder than the ambient though.
  5. saskwoodburner
    saskwoodburner
    Did you change the emmisivity?(how the heck you spell it) of the IR temp gun? My IR gun seems to not read correctly just leaving it set how it it is normally.
  6. Well Seasoned
    Just a magnet on the single wall. IR thermo last night.
    HDRock likes this.
  7. Highbeam
    Highbeam
    450 surface temps are really hot. I first read your temperatures as negative 14 negative 20. How can it be zero at the roof?
    yooperdave likes this.
  8. Well Seasoned
    There is probably some heat escaping at the roof line. Right now my class A on the outside is 7° coming out of the roof and 11° heading up. The cap is 57° new small load just started.
    HDRock likes this.
  9. Oldman47
    Oldman47
    Illinois
    I would say you are running too cold. That 57ºF on the cap means you are getting condensation inside your chimney pipe. Condensation = creosote in my way of thinking. The outside of a class A is almost meaningless since it is well insulated from the inner pipe but the cap is reflecting the "real" flue temperature.
