Choosing a new to me tractor
Discussion in 'Chainsaws and Power Equipment' started by Scout80, Dec 1, 2020.
  1. Scout80
    Scout80
    Wisconsin
    Hello fellas. It’s been a while e since I’ve been on the forum but im in desperate need of some good opinions. I’m in the market to buy a tractor that will be able to move 8 ft logs with a grapple/front end loader from my staging area to where I want the wood cut,split,stacked. Also move and level dirt and grade drive way. And not take up too much room in the shed when parked.
    I’ve decided on a budget of no more that $20,000 with attachments. I have no attachments yet.
    The biggest problem that I’m having on the decision is I’m not yet convinced that I shouldn’t just get an older tractor like an International 454 or some such other utility model tractor.
    I am my own mechanic for the most part but I do not want something that ends up being worked on all the time.
    So my question is. For the guys that have ran both, are these newer compact tractors really going to handle all that stress for the next 50 years or am I better of getting an older utility model tractor.
    sorry for being long winded but I’m banging my head against the wall.
    M2theB, Hammy, Spencer and 2 others like this.
  2. Creekin
    Creekin
    Manitoba
    Ive borrowed a friend's new holland (28hp?), felt solid enough for the size, but lacked power on the loader
    Sure feel the flex in the frame going through uneven ground
    This past summer I used an old international construction tractor, its a beast! Super durable
    M2theB, Hammy, Spencer and 3 others like this.
  3. amateur cutter
    I'm a fan of the old iron for sure if you can find a decent one. Only drawback is most aren't 4wd & need chains in snow country. They make less horsepower per pound & don't break easily. The must haves are power stg. 3point hitch & 3rd function on the hydraulics if you're gonna use a grapple. That being said, I bought a 2000 TYM T390 with a loader this summer, & so far it's been solid. Lifts more than I would've thought, I'm fairly certain my old M would pull it backwards, but it's a much more user friendly machine.
  4. DNH
    DNH
    Missouri
    I run a 45 HP international with a loader. Loader capacity is about 1800 pounds and 3 point capacity about 2500 pounds, does a great job I moved over 500 tons of material with it. For what you are looking for I’d look at the following
    1) Ford 5000 (75’ish hp) with dual remotes on the back, fit your third link with a hydraulic cylinder and mount a grapple/pallet forks. Great for grading and moving stuff. Around here cost 6-10K if you look around. Rent a Skid steer for $500 bucks and do 10x the dirt work when needed
    2) 35 hp minimum compact tractor, if used heavily the loader will not hold up. New or low hour tractor $15-25k, best friends dad just shattered mid range on the transmission on 45 hp tractor cleaning out pond/moving round bales with less than 2000 hours on it.
    3) miniskid or skid steer can get a good used unit with 2000-2500 hours that will hold up to almost any use you can throw at it for $15-25k. BUT front mounted brush hogs, grader blades, box blades are 10x cost of same equipment that is 3point mounted.
    M2theB, Hammy, Spencer and 4 others like this.
  5. farmer steve
    farmer steve
    top of the hill york co. PA.
    Bigger is better. :thumbs: Depends what logs your moving. A 20 inch,8 ft. green oak log weighs a bunch. To much weight on less than adequate front tires will cause you problems. 4WD is a must as is a block heater. Don't skimp if you want it to last.
    M2theB, Horkn, Hammy and 3 others like this.
  6. Scout80
    Scout80
    Wisconsin
    Thank you for all the responses.
    any thoughts on the early 2000s New Holland tc40.
    Found one for $15,000 with loader and 700hrs.
    also found a John Deere 1020 with loader
    M2theB, Horkn, Hammy and 4 others like this.
  7. Ward Hoarder
    Ward Hoarder
    West Virginia
    We have a 07 TC30 like the tractor. Surprised at what it will do.
  8. farmer steve
    farmer steve
    I have the TC55DA and been pretty good hauling wood. I wood have gotten bigger but I needed to be able to get in my barn to dig out manure. I have ballast in the rear tires and that helps. How many hours on the tc40? FWIW I Just had to put front tires on mine to the tune of $600. Make sure what ever you look at has good tires.
    Horkn, Hammy, Chvymn99 and 2 others like this.
  9. Scout80
    Scout80
    Wisconsin
    Just looked at the mew Bobcat ct4045. Just under $25,000 with loader:faint:
    Pretty much a Kioti.
    Bobcat is $500 cheaper and rated 400lbs more on the loader. And a bit more refined I think.
    I found a 35 hp Kioti from 2013 and only 300hours on it for $15000. Only rated at 1155lbs on the loader. Guy traded it in for a bigger model.
  10. brenndatomu
    For old iron I'd add live clutch to that must have list personally...
  11. Homemade
    Homemade
    Wisconsin
    Any thoughts on kubota. We had some smaller units bc2300 if that sounds familiar, at work and they took a pounding.
    amateur cutter, Horkn and Hammy like this.
  12. Scout80
    Scout80
    Wisconsin
    I’d love a kubota. The price is just too high as far as new goes. In my opinion if you find a used one that is only a couple years old, they hold there value so well that the price isn’t much different than buying new.
    And that like I said is IF you find a used one in a model that your looking for.
    M2theB, amateur cutter, Horkn and 2 others like this.
  13. Scout80
    Scout80
    Wisconsin
    The equivalent kubota tractor to the Bobcat I looked at is 10,000$ more
  14. sirbuildalot
    sirbuildalot
    Mass
    I had a similar experience when I went tractor shopping in 2017. I was originally thinking Kubota, until I got the prices back. The Kioti came with better specs (lift capacity-both loader and three point, more GPM of flow, more options standard instead of extras on the Kubota, etc. A comparable Kubota was 8-10k more than the Kioti. Resale value didn't mean that much to me as I plan on keeping my tractor for a long time. The biggest plus to Kubota was the dealer was closer.
  15. JCMC
    JCMC
    Just outside of Shushan, NY
    I am happy with my Kubota it does not have the lifting capacity that my old one did but i make due.
  16. mike bayerl
    mike bayerl
    FYI, an 8 ft x 20" oak log weighs about 1200#. Ballast on the 3pt hitch is a must and loaded rear tires is highly desirable when lifting weight with a compact tractor. You will need a 3rd function hydraulic to run a grapple, ~$800-1000 add-on if you do it yourself. I'd try hard to get an older unit at your budget. You will get more total weight and power for the money and you can avoid the Tier IV emissions (DPF, urea injection, SCR/EGR, etc.). I lucked into a used Kubota, but they are not always available.
  17. mike bayerl
    mike bayerl
    Be careful about getting hung up on all the specs. Many of them are highly non-standardized. They may be useful comparing various models from a single maker, but don't always work when comparing across brands.
    huskihl, M2theB, Stlshrk and 4 others like this.
  18. Scout80
    Scout80
    Wisconsin
    Mike
    Thank you for bringing up emissions
    I didn’t really think to much about it.
    now you made it that much harder to make up my mind lol.
    kind of comes down to rugged simplicity or refined pane in the butt.
    Horkn, Hammy and amateur cutter like this.
  19. mike bayerl
    mike bayerl
    It's just one piece of the puzzle, some of the newer models from the better makers have reliable emissions system, but yes, simplicity is very nice.
    Horkn, M2theB, Hammy and 1 other person like this.
  20. Scout80
    Scout80
    Wisconsin
    So do you have any knowledge of the new Kioti/Bobcat tractors by chance? The Cat I’m interested in is first year model also. Not very encouraging. But I still haven’t turned away yet.
