Chimney vs Flue
Discussion in 'Modern EPA Stoves and Fireplaces' started by fox9988, Mar 17, 2019.
  1. fox9988
    fox9988
    NW Arkansas 72717
    I tend to use the terms interchangeably. But if I consider it, I think of chimneys as masonry and flues as stainless. I rarely see “flue” used on FHC, maybe it’s a Southern thing.
    Which/how do you say it?
    saskwoodburner and wildwest like this.
  2. wildwest
    Wyoming high plains
    I grew up calling the masonry chimney fireplace "the flue" in Colorado.
    saskwoodburner and fox9988 like this.
  3. saskwoodburner
    saskwoodburner
    Geez, made me think.:D I seem to in general terms refer to the whole works as a chimney (time to clean the chimney) but also call it the stack. When I refer to temps, I seem to say flue temps or stack temps (the flue probe is showing 500 f). I'm gonna go confuse myself a little more now.
  4. bushpilot
    bushpilot
    Eastern Washington
    I usually am talking about the outside part when I say chimney. The flue to me is the inside part, aka stovepipe. The stack is the whole thing.
    And I don't have a clue if I am right.
  5. DaveGunter
    DaveGunter
    I think of the chimney as the structure that holds the flue (smoke path) so for modern pipe chimneys they are one in the same, many masonry chimneys contain more than one flue or smoke path.
  6. fox9988
    fox9988
    NW Arkansas 72717
    Good point.
    saskwoodburner likes this.
  7. coreboy83
    coreboy83
    NW of Twin-Cities
    For me,, my chimney is made of brick and it holds my flue pipe.
