Chimney installed and chased in. But have a ?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sconnie Burner, Oct 1, 2016.
  1. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Here it is ready for inspection Monday morning:
    The roof part of the chase got built a little taller than I wanted though. Is 7" to the top of the pipe and 11" to the top of the cap going to be ok?
  2. Matthewchopswood
    Matthewchopswood
    Shenandoah Valley, VA
    Looks like it will be easy to clean. You might need a ladder for top down cleaning but it should get plenty of draft.
  3. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    I'm unsure about the clearance. It sure sounds too tight. Hope someone else can chime in for ya.
    Looks like it's coming along. Hope you get it dried in quickly Sconnie Burner!
  4. Backwoods Savage
    It probably will depend upon the local code.
    Flatlander Pete likes this.
  5. Canadian border VT
    here it would be yes, my insurance wanted a chase because of winds and my proximity to the lake... your inspector will let you know your codes..
  6. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    No certain distance above chase top required according to the inspector that looked at it. I'm 3 inches on all sides in the chase itself. She said I only need 1"? Pipe tag says 2". Chimney guy says a 12" extension can be added. His only worry about the shorter distance was some discoloration on the chase do to the close distance to the cap. Guess I'll run and add to it of need be!!
