Checklist for install
Discussion in 'Modern EPA Stoves and Fireplaces' started by capetownkg, Sep 21, 2015.
  1. capetownkg
    capetownkg
    southern, MD
    Ok well I plan on ordering my liner this week. So figured I would put up my list and see if you guys think I missed anything.
    25ft liner with insulation
    13x13 top plate
    Metal sheeting for block off (recommendations on gauge?)
    Masonry screws
    Metal blades for sawzall to cut damper or grinding wheels for grinder
    Hi temp sealant
    Roxul for block off
    Thats all I can think of right now. If there is anything that could make it easier, or something I am missing please shout it out. Its a 6inch liner going down a 13×13 clay lined chimney. 316 or 304 stainless not sure of the pros and cons. As always thanks for the input and help.
    wildwest likes this.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Just off the top of my head...
    Appliance connector or tee ?
    Cardboard for block off plate template.
    Self tap metal screws
    Metal snips
    Pop rivets
    Jig saw with metal blades.
    Sealant for the top cover.
    Patience.
    I saved some insulation to wrap around the flex liner where it went through the block off plate. It is held up in place by a large metal hose clamp
  3. wildwest
    Wyoming high plains
    If your liner is separate (not a kit) you will also need spray adhevise and wire screen. We had 2 people to straighten it out and apply the insulation/screen, could have used more.....
    papadave and fishingpol like this.
  4. fishingpol
    fishingpol
    That is a good point. The mesh wrap on mine was loose, a one size fit all type. We skipped the adhesive but used the mesh over the insulation. I also bought some bare steel wire and put a wrap every two feet or so to keep the mesh in place and minimize snagging.
    papadave and wildwest like this.
  5. wildwest
    Wyoming high plains
    x2
    i bought a roll of cut to fit like this, [​IMG]
    but it still snagged, bare wire :thumbs:
  6. capetownkg
    capetownkg
    southern, MD
    I think I will be getting a kit. But if not your just talking about something to wrap on the outside of the insulation to keep it all together?
  7. Locust Post
    I don't see chimney cap.
    The wire that has been mentioned is a good idea, I did that also with mine.
    I bought from Rockford and see they have a 10% off deal going on right now.
    If you can't get a block off plate up in there very easy you can just stuff Roxul in, mine has been just fine....4 th year I think now. Had it on my old stove for 1 or 2 years.
    I just looked again and see the liner kits come with cap but I preferred the hinged swivel cap.
  8. wildwest
    Wyoming high plains
    Not positive but I think the wire mesh is to protect the insulation, not necessarily keep it together. My insulation was fleece batting on the inside with a foil liner on the outside. The foil tears easily. My kit was similar to this, so something to get the liner down the chimney without getting the insulation torn off on the way down. Kinda like super light gauge chicken wire only in 1/2" openings....
    papadave likes this.
  9. capetownkg
    capetownkg
    southern, MD
    Ok so have done some looking around and this is what I think I will be going with.
    6" 316 Flexible Chimney Liner Tee Kit or Insert Kit with Optional Insulation
    Seems to have all I need. The top plate isnt as nice as I would like but for the price I could easily pick one up elsewhere. 316 stainless liner 6"x25ft with insulation appliance connector and top cap for $534.99. Any thoughts or experiences dealing with them, the company is Rockford Chimney Supply.
  10. fishingpol
    fishingpol
    I am not sure if you have a few inches of terra cotta clay chimney liner above your brick chimney, but I bought the terra cotta cap that has four masonry screws. the cap was sealed to the top of the terra cotta and then screwed in hand-tight. It has been rock solid. It is a well made cap. It is listed under components for round liners. I had the option to pick that one for a slightly higher cost at the time.
    Terra-Cotta Top Plate - Product Info | Rockford Chimney Supply
  11. wildwest
    Wyoming high plains
    Good point!! I forgot, we had to special order one in the right size....
  12. capetownkg
    capetownkg
    southern, MD
    I have a 13x13 rain cap now that has the screws. I was planning on putting the top plate on, cutting the liner almost flush and then putting my rain cap back over it all.
  13. fishingpol
    fishingpol
    Gotcha. The rain cap should be high enough over the collar on the top cap.
  14. Locust Post
    My experience with them was super, I'd gladly refer anyone to them. If you go directly to there sight they are showing 10% off. Not sure how that compares to their e-bay price you linked in your post. One other thing that I found very helpful that you can purchase from them is what they call a pulling cone I believe. It attaches to the end of the liner with a hose clamp just like your appliance connectors do then you can attach a rope to it and drop it down the chimney to help pull it down if you have any slightly off set tiles, it is very helpful.
  15. capetownkg
    capetownkg
    southern, MD
  16. Locust Post
    Don't know much about the stuff you show here, but I have quite a bit of Roxul and would be glad to ship you some if you like. Gonna jump off here to mow but just send me a PM if you want to work on that.
    milleo and papadave like this.
  17. FastDonzi
    FastDonzi
    East TN
    On mine, I have a Storm Collar right below the Cap (My cap mounts in my 8" pipe) I guess its to stop wind blown rain from running down the pipe...Idk, it came with the kit..
  18. capetownkg
    capetownkg
    southern, MD
    Wow thanks for the offer Locust Post but I saw this late and already ordered this other stuff. Again thats what makes FHC an awesome place members like you!
  19. Locust Post
    No problem, if the other stuff doesn't turn out to be what you want just let me know. I bought a full bat when I did my stove and used the rest for some insulating in the garage but came up short on that so eventually bought another full bat, have over 1/2 of that left.
