Check your spark arrestors!
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Oct 14, 2022.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Buddy brought his Stihl BG55 blower over. Said it had no (eagle) powers.
    First thing I did was grab my 15mm socket and pull the spark arrestor plug and this is what it looked like - completely plugged.
    Got the propane torch and 15 seconds later it turned to this.
    Then the wire brush and the BG55 was back in business.
  2. Firewood Bandit
    Firewood Bandit
    Kinda looks like a good thing to cut off and just put the plug back in and retune.
  3. Camber
    Camber
    Montana
    I check mine when I first buy a saw. Then noticing that they are a hindrance, I throw them away.
  4. isaaccarlson
    isaaccarlson
    Colfax, WI
    I toss mine. Call it a budget muffler mod.
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great job finding that !! I have the exact same blower ! Mine from new wouldn't run right..so I ripped that screen off...runs like a top . Sounds really cool now too !
  6. amateur cutter
    Yep, they're more like HP arrestors. If you work in really dry areas I can see the need, but otherwise trash.
  7. isaaccarlson
    isaaccarlson
    Colfax, WI
    Speaking of sparks/dry areas....
    I have run a lot of 2 strokes in dim light or in the dark, and I have not seen a spark come out of a properly tuned and maintained 2 stroke. I have seen plenty of sparks from rocks, dirt, or high mineral wood (iron wood throws sparks like a grinder and it looks really cool in the dark). If you have carbon deposits that are heavy enough to break loose and start a fire, it's time to change your habits. The most I get is a very light dusting of soot that wipes off with a finger.
    Any piece of equipment I get that is full of carbon gets cleaned, and the carbon stays gone.
  8. Eggshooterist
    Eggshooterist
    Erff
    He runs Stihl Ultra doesn't he.
  9. amateur cutter
    :rofl: :lol: True, but hilarious.
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    It was actually worse than I thought. I revved it up and it sounded way better than before but then I looked up some videos of the BG55 and this was definitely running rich. Couldn't lean it out any more on the H screw and before ripping out the limiters I decided to pull the muffler and this is what I saw.
    Muffler is shot. I saw the inside and it was caked with carbon. No point in trying to clean that. Ordered a new oem muffler.
    Piston looks good.
  11. Eggshooterist
    Eggshooterist
    Erff
    Put that guy on Red Armor, Amsoil Dominator or Honda HP2 oil. There will be no more of those issues.
    Woodsnwoods, huskihl, SimonHS and 6 others like this.
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    Yes sir I remember your posts. I recommeded the Echo Red Armor since it's so easy to get at the Depot.
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    What do you guys think of Husqvarna xp oil ?
    I've been using it for a long time..seems ok.
    Starting to run low in my gallon jug...if there's something better..im all ears to try!
    Woodsnwoods and In the Pines like this.
  14. Eggshooterist
    Eggshooterist
    Erff
    You want added to my oil test madness? You can decide for yourself then.
  15. Eggshooterist
    Eggshooterist
    Erff
    The fast answer is if it has been working for you then have at it. There are way worse oils and several better. This based on the testing I've been doing for nearly three years now.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Fill me in. What's better ? I see the Echo Red Armor is getting great reviews ! Like I said..im getting ready to run out of Husky oil..id be ok switching and trying ! Always willing to try something else out !
  17. Eggshooterist
    Eggshooterist
    Erff
    Amsoil Dominator, Honda HP2 and Echo red Armor are best of the best so far. Oh, Castrol GO full mineral is excellent too but not as clean.
  18. Eggshooterist
    Eggshooterist
    Erff
    There are many good oils. Amsoil saber, Ipone Samurai, motul 800, blue marble. Maxima K2.
  19. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I appreciate the headsup ! I think I'll try something different this time. Thinking Echo...but who knows. Thanks man !
  20. Eggshooterist
    Eggshooterist
    Erff
    You can't go wrong with echo red armor.
