Chainsaw Vise
Discussion in 'Chainsaws and Power Equipment' started by Oliver1655, Mar 4, 2014.
  1. Oliver1655
    Oliver1655
    Central Missouri
    Finally got around to building a chainsaw vise for holding the bars while filing. It's nothing fancy but with a couple of screws or a clamp you can mount it most anywhere.
    A simple $6 hold down bolted to a bent piece of 1/4" steel plate. The rubber headed bolt for the hold down was replace with a piece of 1" angle iron. To allow this piece of angle iron to pivot/rotate to match the bar, I loosely sandwiched the head of a 5/16" carriage bolt between the angle iron & a flat washer which was welded to the angle iron. The rubber pads keep the vise from pushing against the chain while protecting the bar & keeping it from sliding in the vise. The file guide is a Stihl 2n1.
    The larger saws will set directly on the bench.
    For the smaller saws I use a small piece of 2x6 under the power head.
  2. bogydave
    Nice idea
    Looks like it works well
    Oliver1655 likes this.
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    Is that also secured to the benchtop?
  4. Well Seasoned
  5. Oliver1655
    Oliver1655
    Central Missouri
    There are 4 screw holes which can be used to fasten it down. I use 2. One each in opposite corners.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Beats the regular bench vise i currently use !! Lookin good :)
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    Wanna make another? :whistle: I know a guy, who knows a guy, who wants one like that :D
    Looks good man. That was well thought out.
  8. Oliver1655
    Oliver1655
    Central Missouri
    Never know, the Lord works in mysterious ways. :whistle:
    DexterDay likes this.
  9. GrJfer
    GrJfer
    The Woods of Arkansas
    Nice home made vice. Looks like it works well.
    How do you like the Stihl 2n1 sharpener? I had one and like it a lot. Always had trouble keeping the correct angle. It has helped me greatly.
  10. Oliver1655
    Oliver1655
    Central Missouri
    Works real well.
  11. Sinngetreu
    Sinngetreu
    North Central Iowa
    Man, I digging this idea. Do you have any problems with the chain hitting the vise at all?
  12. Cut4fun
    Cut4fun
    OHIO Redneck
    If I am going to leave chain on the bar to file at home. Rotating vise is my choice.
  13. Oliver1655
    Oliver1655
    Central Missouri
    Nope! Notice the jaw opens wide. One of the reasons for the wood spacer & rubber blocks for the jaws. With the rubber blocks only 1" tall, if you clamp on the lower portion of the bar it keeps the file & your hand from hitting the vise, well in most cases. :confused: There will always be someone who does to prove me wrong. :whistle:
    You can rotate the vise any direction you want, provided you have a place to screw it to, even a wall.
    Sinngetreu likes this.
