Chainsaw long storage ?
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Nov 18, 2014.
  1. bogydave
    Pulled / cleaned the bar, greased tip
    blew out the saw body & brake cover. Greased bearing
    Sharpened the chain, (Master Mechanic was right, rakers were high)
    bumped the rakers.
    Dumped the gas, & ran it till it died.
    Anything else need / should be done ?
    Bluelou and Chvymn99 like this.
  2. MightyWhitey
    MightyWhitey
    Wash and wax??:D:rofl: :lol:
    HoneyFuzz likes this.
  3. bogydave
    Maybe in a week or two, after the oil quits running out the bottom of the saw.
    Cold storage might thicken the oil & it''ll leak for a month. :confused:
  4. JRSDWS
    JRSDWS
    Central Illinois
  5. bogydave
    Thanks
    Got some outboard engine fogger, that should work
    Give me a reason to pull the spark plug
    & maybe even replace the plug after 3 years :bug:
  6. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Do it while you're in there! I was mowing a couple months back, mower wouldn't run. Needed a new plug but no vehicles at home. Had to walk a couple miles to the saw shop and back to get a new plug and filter. I wasn't a happy mower that day :rofl: :lol:
    Fix it 'fore it's broke if you ask me :D
  7. Bluelou
    Bluelou
    Northern il.
    go outside cut more wood and start all over. other then that your good to go. LOL
  8. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Make sure you crank it again after it dies. I can normally start mine a couple of more times, that way I know they are dry.
    mdavlee and bigbarf48 like this.
  9. bogydave
    Yea
    Pulled the choke & it fired up twice more.
    No throttle control but it ran for about 5 - 10 more seconds.
  10. redneckdan
    redneckdan
    Northern Minnesota
    I usually run the last tank with stabil incase I don't get all the gas out.
  11. bogydave
    The 2 cycle oil (amsoil) I use, has fuel stabilizer in it.
    Several oils have a stabilizer in them.
    Part of my concern is the effect of gasoline & various chemical compounds in the vapors
    on the saw's plastic & rubber parts. I leave the gas cap open too (saw in a case)
  12. Guido Salvage
    Guido Salvage
    On my Pioneer saws the caps swell when in contact with fuel, I leave them off and stuff a rag in the hole.
