chainsaw Cylinder & pistons
Discussion in 'Chainsaws and Power Equipment' started by rusty ranger 44, Mar 28, 2024.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    Hello All I recently picked up a Stihl 026 on marketplace. I have not been able to start this project yet.I have a needed fuel line and impulse line on order from stihl. The parts that came the saw had chinausm fuel line and impulse line. The cylinder looks good, however I would like to replace it with a new one that is known to be good. Looking to the saw builders out there as to their recommenced supplier for 026 stihl cylinder & piston. I have seen them listed for a lot and very cheap.
  2. The Wood Wolverine
    My money only goes to oem cylinders. If yours is good, I’d clean it up and use it. Maybe post some pics of inside so we can see the in/exhaust ports.
  3. RCBS
    RCBS
    Over here
    I want to believe in the aftermarket P&C's but if the saw is a keeper I would seek out OEM.
    The builders/modders should know the best non-original replacements.
    John D likes this.
  4. Khntr85
    Khntr85
    Indiana
    Take a pic of jug and slug
    John D likes this.
  5. MAF143
    MAF143
    North Central OH
    I know the first saw (MS362) I totally, the OEM cylinder looked totally trashed. The exhaust skirt of the piston had even broken off and the crank was locked up. I posted a pic of the cylinder and the guys in the know told me to clean it up. Almost all of the nastiness was aluminum transfer from the piston overheating and smearing itself on the cylinder walls. I made a mandrel for a drill out of a big spike and used a strip of sandpaper wrapped around it as a flapper to clean that all out. There was very little actual damage to the plating of the cylinder and almost all of that was cosmetic. No real scratches that you could catch a fingernail on. I put new bearings / seals and of course a new piston and ring in and he's still cutting 8 cords a year with it for the last several years.
  6. John D
    John D
    Syracuse ny
    I believe nothing beats oem
  7. Eggshooterist
    Eggshooterist
    Erff
    100%. Id use aftermarket only as a last resort. In fact I have one saw, a Dolmar built Makita, that needed a coil. OEM no longer available because they had problematic coils and the upgraded coils dried up fixing all the problem coils. I ended up finding one company making aftermarket coils for it and so far it's been fine.
    John D and brenndatomu like this.
  8. rusty ranger 44
    rusty ranger 44
    south central Pa
    Sorry I tried and the picture did not take very well or I am not very good at it
    John D, Eggshooterist and Khntr85 like this.
  9. JimBear
    JimBear
    I will go against the grain on this one, Meteor p/c are quality units.
