Chainsaw buddy ?
Discussion in 'Chainsaws and Power Equipment' started by makey98, Dec 27, 2020.
  1. makey98
    makey98
    Indiana
    brenndatomu and Sinngetreu like this.
  2. Scout80
    Scout80
    Wisconsin
    4 pounds added to the saw would be a big pain in the back in my opinion.
    Looks to be a fix to a problem that doesn’t really exist.
    Again
    Just my opinion.
  3. Creekin
    Creekin
    Manitoba
    I would have to agree, not a fan of things hanging off the bar, one more thing to keep in mind and watch out for.
    looks interesting though
  4. Sinngetreu
    Sinngetreu
    North Central Iowa
    Wranglerstar had a video on this if you want to see it in action. IIRC he liked it ok, but nothing fantastic. I'm not endorsing him, but he is the only one I've seen use it.
    My stupid opinion is: I've seen him use it once (but not after that) and I don't see other people using it. I have seen different log holding devices though, so I guess I would chalk it up to being either a specialty tool, a neat idea that didn't take off, or a tool that just isn't that necessary.
    If someone game me one, I probably wouldn't hate it, but its not on my "to buy" list.
    As a side note: When I cut small stuff, I'm usually cutting on the tip of the bar and not the base. If I were cutting at the base for smaller stuff, the wood would be higher in a sawbuck. Cutting small stuff on the ground using this tool seems really awkward. For medium sized logs I would use a log stand and cut in the middle part to lower part of the bar. What I usually end up doing is cutting 3/4 of the way through the log and then roll it and cut the rest of the way. I'm a fan of the KISS rule.
  5. Lastmohecken
    Lastmohecken
    Arkansas
    I guess it depends on the species of tree and how many limbs it has on it, but I don't have to cut that much on the ground, as I try to cut everything I can in the air while it's still attached to the trunk, but like was said, I just cut most of the way through and roll it over and put my foot on it if I have to. Many time you can just lay it over another stick and have air underneath so can cut all of the way through.
  6. The Wood Wolverine
    I wouldn't like something like that attached to my bar. If the limb is movable enough to get underneath, make a cut 2/3rds of the way through and roll it over to finish.
    Scout80, Sinngetreu and Nixon like this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    What He said ^^^^^^^. You’d likely get more use out of a peavey ,or timberjack .
    Scout80, Sinngetreu and Ronaldo like this.
  8. Scout80
    Scout80
    Wisconsin
    I have made something similar to this. Works quite well mounted to the truck bedside.
    JackHammer, Lone_Gun and Sinngetreu like this.
  9. JackHammer
    JackHammer
    That looks like a really good idea. Do you have pictures of yours? Seems like a few spring clamps and a solid anchor with a nut and bolt would get you most of the way.
    Scout80 likes this.
  10. Scout80
    Scout80
    Wisconsin
    Sorry
    No pics at the moment
    It’s not set up. I had my Husky 42 on it and it needs some lovin.
    Yeah. They are very basic setup. I’ll try and remember to throw it back together and get some pictures of it.
    There is a rod that hinges off the top and works the throttle actuated by the log/branch that you ar cutting.
    There are many videos on the net.
    JackHammer likes this.
  11. Scout80
    Scout80
    Wisconsin
  12. JackHammer
    JackHammer
  13. sirbuildalot
    sirbuildalot
    Mass
    Anything small diameter up to about 10” I just put in the sawbuck, usually several at a time. These are done in 10 foot lengths. Large stuff I cut, roll with cant hook and finish cutting.
  14. unbidden
    unbidden
    RI
    Small stuff I just put a piece of wood under to lift off the ground. Larger, I use a cant hook.
