Chain wont Spin
Discussion in 'Chainsaws and Power Equipment' started by Upstatewoodcutter, Nov 29, 2014.
  1. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Well here's a humorous one for you saw guys. Went to go finish bucking up that maple I felled and mentioned the chain amongst other general maintenance. Well in my haste I didn't tighten the bar cover nuts and sure enough the chain popped off. No big deal, so I try to reset the chain and it looked like some of the teeth that run on the sprocket were damaged and wont fit into the bar without force. The question is do I need a new chain? The chain won't spin even when the saw is running.
  2. mdavlee
    mdavlee
    File them down to fit into the groove again.
  3. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Good plan. I shall get to filing.:D
    DexterDay, mdavlee and Loon like this.
  4. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Flat file to remove the burs.
    thistle, DexterDay and mdavlee like this.
  5. RParrotte
    RParrotte
    Saranac, NY
    Dremal with a drum sander works great.
    NewToStihl and Loon like this.
  6. bogydave
    Clean it good with brake clean / soak in a little gas
    don't want filings in the bar grove.
    Check the drive sprocket/rim for damage.
  7. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Filed them down, 2 or 3 were in really bad shape. Set the chain and worked it back and forth and it worked fine.
