chain saw wont rev up
Discussion in 'Chainsaws and Power Equipment' started by clay shooter, Dec 11, 2021.
  1. clay shooter
    clay shooter
    ENGLAND
    went out today the saw started ok, went to cut up the tree and it wont rev up to cut it,starts up fine could i have put to much oil in with the petrol.
  2. MikeInMa
    Try draining what's in there and use some fuel that the mix is known.
  3. brenndatomu
    Some years back I bought a nice lil 42cc saw for $20 that had the same problem...the brake was set....just something to doublecheck...
  4. SimonHS
    SimonHS
    Yorkshire, England
    The mesh screen in the muffler could be blocked? Or the air filter?
  5. amateur cutter
    Yes & yes. Also too lean on the low side can cause that, but the engine will often stall.
  6. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    What saw is it ?
    How old is it ?
    Is the chain brake engaged?
    When it's running and squeeze the trigger, does it make and funny bad noises.
    There must be at least 20 reasons why a saw won't advance rpm.
    More information is needed.
  7. clay shooter
    clay shooter
    ENGLAND
    im having the saw looked at, and iv bought another,i need to cut the trees up. thanks for all the replies.
  8. clay shooter
    clay shooter
    ENGLAND
    the muffler is a fixed box, so cant get in side to clean,so just bought a new muffler box, will fit it and try the week end, thanks
    Screwloose and M2theB like this.
  9. Chud
    Chud
    NC
    Did anyone mention fuel filter or maybe carb screen?
  10. clay shooter
    clay shooter
    ENGLAND
    just fitted it and seems to be ok,the old one looked like a lot of carb in it,the new one you can see right though it.
    M2theB and Mag Craft like this.
  11. Mag Craft
    Mag Craft
    South East Wyoming
    Yep, a blocked spark arrestor will prevent a saw from revving up. Sounds like you found it.
  12. brenndatomu
    Heat it up red hot with a torch...the carbon will burn out and it can be used again if needed...we used to do this at the bike shop on small 2 stroke moped and dirt bike exhaust pipes that would get plugged up due to over zealous auto lube oilers...get the gunk burning inside by heating the right spot up to red hot, then once its smoking good, shut the acetylene off and just blow a lil pure oxygen into the pipe...that would really get things burning! You could actually watch the burn progress through the pipe by watching the orange glow advance down the pipe...man would it ever smoke! And if you held the torch just right, and got the oxygen flow just right, you could make a pipe organ out of it...she'd start a pretty loud low pitch whistle...Honda PA50 Moped exhausts were famous for this!
    Stephiedoll, Chud, MikeInMa and 2 others like this.
