Chain catcher question
Discussion in 'Chainsaws and Power Equipment' started by Sinngetreu, Nov 13, 2020.
  1. Sinngetreu
    Sinngetreu
    North Central Iowa
    I didn't see a thread for this so, at what point should you replace your chain catcher? Mines been hit twice and I'm really wondering if I can just file down the burrs and keep going. I've bent it back into shape and filed it down some to keep from pieces getting sucked up into the drive.
  2. huskihl
    huskihl
    I’d think a long as it’ll do it’s job it’s fine. If it’s been cut halfway through or something similar I’d probably replace it
  3. The Wood Wolverine
    ^ +1 :handshake:
  4. Sinngetreu
    Sinngetreu
    North Central Iowa
    Yeah, its nothing but a flesh wound. I'll keep running with it. Thanks for the feedback.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    I'd be more concerned about why you've hit your chain catcher twice. Are you new to sharpening? Because I broke two chains when I first started sharpening (oct-2019) so I know firsthand.....and I'm 99% sure it was because I was too aggressive with my file and ended up filing the top of the links......and combined with using the wrong file size (i.e. too big) that caused 2 of my chains to snap on me.
    Do you have a picture of it?
    Backwoods Savage and MikeInMa like this.
  6. Sinngetreu
    Sinngetreu
    North Central Iowa
    Both times the chain threw was when I was cutting on the top of the bar after having cut for a while. I think what happened is the chain loosened up and when I switched to the top of the bar it created enough slack over the nose and caused it to slip. I'm not new to sharpening and the chain top side was not damaged when I inspected it. The second time it threw I believe it was exacerbated by a drive tooth that was damaged a bit. Since then, I ditched that chain and inspected the bar and sprocket assembly and filed the catch smooth and everything has been working correctly since.
