Catalytic Wood Furnace
Discussion in 'Modern EPA Stoves and Fireplaces' started by Born2Burn, Feb 3, 2021.
  1. Born2Burn
    Born2Burn
    Youngstown, OH
    In addition to fueling my 2 wood stoves, I'm a good son and process and deliver my parents seasoned wood to help heat their house. I don't mind helping them out whatsoever but there wood furnace is killing me. It's a Firechief FC500 unit and its probably only 10 years old if that. It not only EATS wood, but due to the design it clogs the chimney 5 or 6 times a season.
    Before you ask, I am following the 3 year rule and ensuring all wood is very dry. 15 -20% moisture content. Mostly ash, cherry, hard maple, with some black locust and walnut occasionally. Northeast Ohio.
    Without getting into the details of the chimney issue, it's just not an ideal furnace. It burns alteast a cord of wood a month which is 4 times as much as I burn.
    They are willing to upgrade but they would really like to have a unit, as they do now, that has a blower that can be physically tied into the ductwork of the house.
    Does anyone know of an ultra efficient wood furnace? I know Napolian was making non-cat units that were recently outlawed but I'd prefer a cat stove for the efficiency and long even burn times. Does not need to be pretty as it is in the basement.
    After a bit of a learning curve on how to run a cat stove, I'm sure my aging parents would be thrilled to only load once or twice a day rather than fussing every few hours. And my back would like it too!
    Any ideas?
  2. JRHAWK9
    JRHAWK9
    Wisconsin
    Kuuma Vapor Fire 100.........best on the market.
    Vapor Fire 100 - High Efficiency Wood Gasification Furnace - Kuuma
    There are no cat furnaces I am aware of, and if they are out there, they can't legally sell them anyway if they are not Phase 2 certified. As of right now there are only three Phase 2 certified furnaces available. One is a complete POS and the other was just released this year. The VF100 has been around for decades. They were burning clean well before it became cool to do so.
  3. Horkn
    brenndatomu has a kuuma.
    Anything you can do to reduce the amount of wood that their system uses, will be a welcome addition, by subtraction;)
    mat60, brenndatomu and TurboDiesel like this.
  4. JRHAWK9
    JRHAWK9
    Wisconsin
    I already summoned him. LOL
    I also have one. :) ................................................................ ▼ ▼ ▼ ▼ ▼
    mat60, brenndatomu and Horkn like this.
  5. Horkn
    I'd love to have one as well;)
    Edit, I don't normally have my phone on portrait mode, so I don't see sigs unless I rotate the phone.:cool:
    mat60, brenndatomu and JRHAWK9 like this.
  6. Born2Burn
    Born2Burn
    Youngstown, OH
    What is your wood consumption like??
    mat60 and brenndatomu like this.
  7. Born2Burn
    Born2Burn
    Youngstown, OH
    Another alternative I've been thinking about is the possibility of just setting a regular cat stove in its place and somehow "collecting" the heat and dispersing in ductwork. Probably not the best route....
    fox9988 and mat60 like this.
  8. JRHAWK9
    JRHAWK9
    Wisconsin
    comparing wood consumption of two different heat loads in two different climates is useless. I burn more than brenndatomu does, but I have a higher heat load and live in a colder climate.
    You can read my review I posted a few years ago here, it covers a bunch of stuff, including wood consumption:
    ★★★★★ - Kuuma Vapor-Fire 100 Review
    I'm now burning 6 year old stuff and I seem to be using even less. So far this year I have burned 2.25 cord with 4,432 HDD's. Started burning October 1st.
    mat60, Born2Burn and brenndatomu like this.
  9. brenndatomu
    Meaning that the chimney is not good/right, or that it is always plugged up?
    How big is the house?
    Our place is 1200 ft basement, 1200 main floor, and about 650 upstairs...use 4-5 cords per year to keep the house 72*-ish with a Kuuma VF100 furnace.
  10. Born2Burn
    Born2Burn
    Youngstown, OH
    Chimney is good. It is only a few years old. All double wall Duravent. It plugs in the single wall right off the firebox. I believe it is due to lack of proper flue temp. Thing is, if you really "run" the firechief, it will burn an incredible amount of wood - literally as much as you would in an open fireplace. So they burn it low which provides plenty of heat but does not get the flue hot enough.
    House is a 2600ftsq well insulated ranch log cabin.
  11. Rush Battle
    Rush Battle
    WNC
    The Kuuma VF100 is at least as efficient as a catalytic wood stove, but likely more efficient than most. I think it would be perfect, and you have just the right folks to help you out commenting above! brenndatomu has helped me so much I couldn’t possibly repay that debt.
    woodey, mat60, Horkn and 2 others like this.
  12. brenndatomu
    VF100 would heat that easily...and cut that wood consumption in half.
    Mr Lamppa (Kuuma inventor) heats his own home with an early VF100 that is 30+ years old...says he has never cleaned his chimney...inspect annually only
    mat60, Horkn and Born2Burn like this.
  13. JRHAWK9
    JRHAWK9
    Wisconsin
    mat60, Born2Burn, Horkn and 1 other person like this.
  14. brenndatomu
    From their site...
    mat60, Born2Burn and Horkn like this.
