CargoPro Trailer - any experience?
Discussion in 'Chainsaws and Power Equipment' started by NH_Wood, Mar 6, 2016.
  1. NH_Wood
    NH_Wood
    Hi guys. Wasn't sure where to post this question - feel free to move mods if this is the wrong forum. I'm planning to buy a trailer soon - before June. Will be used this summer to haul my motorcycle to work in the midwest - then it will be used to haul some wood, atv, etc, etc. I've heard some bad things (and good things) about Tractor Supply trailers. My local Arctic Cat dealer sells Cargo Pro trailers. All aluminum. Looking at a 5x8 - should be fine for what I'll be doing. Anyone know anything about quality of this make of trailer? Any info welcomed - thanks! Cheers!
    2015 CARGO PRO 5 X 8 UTILTY
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I think that I would avoid a trailer with wood sides, with the standards in the stake pockets where are you going to tie anything down? The one next to it with the metal sides would be a better choice for me. It looks like it has running liters on the front which is nice.
    clemsonfor, Barcroftb and TurboDiesel like this.
  3. NH_Wood
    NH_Wood
    Thanks Guido - I figured I'd add tie downs to the bed for the bike. Looking at cost - moving up much from this gets out of my price range pretty quickly. I'm hoping the quality is good - good welds and good gauge aluminum, etc. I think I could handle the wood sides. Appreciate your input! Cheers!
  4. TurboDiesel
    That is a nice looking trailer, But I agree with Guido.
    Go with the metal rail around the top. Makes the trailer much more rigid.
    The extruded framerails on that trailer are very nice.
    I don't think you would have a problem with the wood sided one unless you are loading it to the max. Which you could do easily with a cord of fresh cut firewood.
    I'm guessing that is a 3000 pound trailer?
    It would "legally" only haul about half a cord of fresh oak
    My biggest gripe about TSC trailers is the frame not being rigid enough on the flat deck trailers.
    Last one I looked at I twisted the frame corner to corner just by putting my weight on one corner. No problem though, I twisted it back by jumping on the other corner.....sad
  5. NH_Wood
    NH_Wood
    Good points. I'd love to go with metal side rails - just can't jump up so high in price. Would you go with a Tractor Supply trailer with metal rails over this one with wood rails? I was hoping to spend a little more for better quality - but if the wood rails are a bad idea, I can save hundreds and give TS a shot. Cheers!
    TurboDiesel likes this.
  6. Eric VW
    $1700 for 5x8? That either seems high or it is because it's alumiyum?
    Yes, I spelled it that way.....
    :D
  7. NH_Wood
    NH_Wood
    Yep - the aluminum jacks the price up a lot. No rust issues so expected to last longer - at least that's the story! Cheers!
    clemsonfor, Horkn and Eric VW like this.
  8. Horkn
    If you are going to haul a bike, put a wheel chock in the bed. You'll appreciate it when you go to haul your bike.
    clemsonfor, Eric VW and TurboDiesel like this.
  9. TurboDiesel
    1700 for a 5x8 is very expensive.
    you could get a nice steel trailer for about half of that is your looking to save money.
    But I'll admit , I'm partial to alunimin. ;) My tilt deck and snowmobile trailer are both aluminum.
    Eric VW and Horkn like this.
  10. TurboDiesel
    ^^^this^^^
    clemsonfor, Eric VW and Horkn like this.
  11. Horkn
    Silly Euro's adding an extra letter in there. :loco: :crazy::headbang:
    clemsonfor and Eric VW like this.
  12. TurboDiesel
    removable wheel chock kit
    the key hole brackets stay on the trailer
    check the width of your tire if its wide
  13. TurboDiesel
    Not sure what that trailer is in the pic, but stay away from torsion axles if you can. they are over rated IMO
    the pic looks like a torsion axle
  14. Horkn
    Pingel, made in Wisconsin.
    I welded my own up, made 3 at a time.
  15. Guido Salvage
    Guido Salvage
    Per the sticker in the 2nd picture on the website, it shows 2200 pounds. Not sure if that is the gross weight or the payload.
  16. NH_Wood
    NH_Wood
    Like that tire chock - will do! I think payload is about 1850 on the aluminum trailer. Cheers!
    Eric VW likes this.
  17. TurboDiesel
    Good eye, Guido
    bet that is gross weight
    Eric VW likes this.
  18. Horkn
    I've got wood sides on my 4x8, but it's a steel trailer. So it's a little different.
    I load mine up pretty well. A solid half cord of fresh cut beech today. It squats a little, but it rides well. IMG_20160306_132903310_TOP.jpg
  19. Horkn
    This is a better design of a wheel chock. Extreme Max Motorcycle Wheel Chock - Walmart.com
    You drive into it, and the back part flips up, cradling the wheel. It's a ripoff of a great, but expensive baxley brand chock.
    Made in the USA too.
    NH_Wood and TurboDiesel like this.
  20. TurboDiesel
    hey this reminds me . I gotta figure out how to get 2 bikes tied down in the toy hauler before Dennis' gtg:handshake:
    Horkn and NH_Wood like this.
