CAB50 problem
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by susancam, Mar 23, 2018.
  1. susancam
    susancam
    Oregon
    I am new here & looking to see if I can some help on an issue I am having...
    My son cleaned our stove & while doing that he knocked off the thermocouple cover & sucked it up. We got a new one & put it on. Now the stove is not really working. If we push the reset button pellets will drop into the pot & they start. It will go through the 1st cycle but then when it turns off it won't restart. The fan will keep blowing but no pellets will drop. TIA
    imacman, ivanhoe and slvrblkk like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    First off, welcome to the board!
    So what your saying is the red call light comes on, the pellets drop and and the pellets actually ignite?
    imacman, ivanhoe and PelletHound like this.
  3. Blithering Idiot
    Blithering Idiot
    NE Pa
    When it does not restart, is there a blinking light on your control box? (I think the box is above the red call light.) If so, he probably damaged the thermocouple too.
  4. susancam
    susancam
    Oregon
    Thanks for the welcome!!
    Where is the red call light
  5. susancam
    susancam
    Oregon
    Not sure where I would find the control box or blinking light.
  6. slvrblkk
    slvrblkk
    Northampton, PA
  7. susancam
    susancam
    Oregon
    Thanks so much I will have him look when he gets home. 1st time in 3 years we had an issue. Little things can sure be picky.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Make sure the thermocouple wire is FULLY inserted into the white ceramic cover and like BI said there's a chance the thermocouple wire is broken.
    will711, imacman, ivanhoe and 2 others like this.
  9. susancam
    susancam
    Oregon
    Will reply back after we look into this info I have received here
  10. slvrblkk
    slvrblkk
    Northampton, PA
    The thermocouple wire should be touching the front of the white ceramic cover, that what I mean by fully inserted. Just wanted to clarify.
    imacman, ivanhoe, PelletHound and 2 others like this.
  11. Blithering Idiot
    Blithering Idiot
    NE Pa
    I'm not familiar with the layout of your stove... only that it uses the same components as my QuadraFire. The manual that slvrblkk pointed you to will be very helpful.
    Regarding the lights: the red call light will be very bright red whenever the thermostat calls for heat (wants the stove to be running).
    The LED(S) on the control box above it will glow amber and then red as the thermocouple heats up to normal fire temperature.
    If you see a continually blinking (about once second) LED on the control box, it's telling you that the thermocouple is bad and the stove will not feed pellets.
  12. Dpopps
    Dpopps
    MI
    You can see the light ,if you look at the back left side of the stove, by the OAK.
    If it drops pellets and fires, then don't drop any more and goes out Sounds like the thermo couple.
    When you put the cover and thermo back in did you place it out far enough into the burn pot?
    Was the thermo wire bent or kinked during any of this?
    imacman and ivanhoe like this.
  13. susancam
    susancam
    Oregon
    We are back up & running. It was a bad thermocouple as you replied. I want to thank all for the help with this.
  14. imacman
    imacman
    Denver, NC
    Welcome to the forum. :handshake: Hang around here a while....lots of great, friendly people, and you'll learn a lot.
    Glad you got it fixed.
  15. Lousyweather
    Lousyweather
    Im not friendly.
  16. will711
    will711
    Pocono Mts.
    Or Great :rofl: :lol::rofl: :lol:
  17. Lousyweather
    Lousyweather
    yea, that too!
    imacman, ivanhoe and Eric VW like this.
  18. Eric VW
    Just misunderstood?:whistle:
    I think yer amicable....does that count?:cheers:
    imacman, ivanhoe and Lousyweather like this.
  19. Lousyweather
    Lousyweather
    Im a miserable bastid
  20. Eric VW
    Ray of gray, eh?
    :whistle:
    :wacky:
    :salute:
