BuZZsaw's epic honey hole score, take 9!
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jun 5, 2019.
  1. buZZsaw BRAD
    I went to the honey hole yesterday with the intent of coming home with a full load of red oak. Well no such luck. I bucked the first log and went to split with the Fiskars...several whacks and nothing. Had to roll them off the deck and sledge and wedge into quarters, upper tree section with more knots and twisty grain. Bucked another behemoth ground level, but couldnt roll it to finish cuts. I got too tired and aggravated and came home empty! First time for that. Went back this afternoon and brought the 28" bar with the intent of finish cutting, but the thought of it dulling fast in the dirt/grit stopped me. The log was wedged against another. I had to cut off the hinge and with the peavey i was able to engage, roll it, and finish the cut with the 20" bar. Log blaster and Fiskared them into sixths to load. IMG_0453.JPG IMG_0452.JPG IMG_0455.JPG IMG_0449.JPG
    Cut off hinge that was wedged against the other log so i could roll it. Actually wired brushed dirt and gravel off to cut it. IMG_0448.JPG
    Had to tap the hook to engage it enough to roll. Took a few attempts.
    Twice as wide as it is long
    BIG rounds. I give you trailer guys a lot of credit for rolling these to load!
    The deck as i left it today. Short log has a branch off the back holding up another behemoth diagonally. Gonna be fun to cut that one next time!
    sections ready for the Fiskars behind my shed.
  2. Midwinter
    Is there any way you could pull logs with your truck to roll them? Maybe get a winch? That looks soooo difficult.
  3. BigPapi
    BigPapi
    The hills of Western MA
    First thought I had as well, though I have pulled with the truck personally, not having a winch. Working a pile with limbs like that can be easier with a chain and/or strap to tug logs that are hung up too much to cut safely.
    Triaxle loads are easier - already limbed fully so everything rolls pretty easy. ...sometimes too easy. :)
  4. Scout80
    Scout80
    Wisconsin
    Nice haul buZZsaw BRAD
    Most red oak here that size that I get would be hollow. Very nice :salute:
  5. jo191145
    jo191145
    Ct
    Yeah Brad. A tow strap or something just to wiggle em out of the hole.
    If you can get a strap under em you can cinch it in or near the middle. Then wrap another turn to two and the truck will roll it over for you.
  6. amateur cutter
    The man obviously speaks from experience & I fully agree. I'd rather burn diesel fuel/gas than calories any day.
  7. buZZsaw BRAD
    I had though of rigging something to tie a rope to on the back side of the log and use PU just to rotate it and finish the cut. Honestly it rotated pretty "easily" with the peavey. Ground was nice and level plus log uniformly round. Ive been hesitant on that one for that reason. The rest look easy as a third log is underneath. BigPapi your white oak log is the second big un in second to last pic. 32" bottom, 22" top....21' long
  8. jo191145
    jo191145
    Ct
    Third pic down. Behind the pile of crushed stone. There lurks another monster.
    They sure grew some big ones down yonder.
  9. buZZsaw BRAD
    I cant have that one. The guy redoing the old building (dates back to colonial times) is sawing a slab for a bar or tables out of it.
  10. amateur cutter
    I've got one about that size out back I gotta finish up. Bit more than a phone pole to wrestle.o_O
  11. buZZsaw BRAD
    biggest oaks ive ever cut. Believe it or not, two years ago i wouldnt have touched these.
  12. jo191145
    jo191145
    Ct
    I wish him luck. A slab of oak, maybe oak, is gonna want to fold up like a cheap suit.might have to park an excavator on that slab for four years.
    Not my area of expertise tho. Just know if I attempted it how it’d turn out. Firewood. Hahaha
  13. jo191145
    jo191145
    Ct
    Oodles of noodles. ;)
  14. buZZsaw BRAD
    theres a big skidder/sky fork parked out front so he has the means to move it. I agree, it'd be firewood if i attempted as well.
  15. amateur cutter
    For sure, likely about 1/4 cord of splits when done.
