Burning bark!
Discussion in 'The Wood Pile' started by Cash Larue, Nov 4, 2021.
  1. Cash Larue
    Cash Larue
    Pine, CO
    I typically rake in the bark after splitting and burn it in my fire pit. But I collect the thick Douglas fir bark to burn in my wood stoves. It burns hot, clean and for a LONG time.
    I collected this Doug Fir bark yesterday after splitting. It’s all I’ve been burning tonight.
    It’s 10:45 and I’ve burned 5 small slabs of bark since 6 pm. It’s 28 degrees outside and 77 in the house.
    I’m not saying it’s black locust or anything. But it’s good shoulder season heat - and it won’t end up in a landfill.
    Anyone else burn bark during shoulder season?
    AE1102F6-3243-453C-8552-C19B1CC940BB.jpeg 7866C9B2-D7B6-4AFD-A163-092D0202C88C.jpeg 94E3B324-F055-4144-9D75-4D2A694851E5.jpeg
    PatrickNY, MikeInMa, Chris F and 32 others like this.
  2. Pricey106
    Pricey106
    Northeast PA
    Yes!!! A fellow bark burner!!! I won't go through the trouble of bringing it inside, but what falls off in the indoor wood bin, gets put in a box, then some days I have a bark fire. I have had a good flame and coals for over 4 hours on about half a copy paper box amount. Waste not, want not. Why haul it back outside?
    Timberdog, Biddleman, Slocum and 13 others like this.
  3. Woodwidow
    When Douglas fir bark is dry, it produces some serious heat. It was quite something when we burnt it in our old Jetstream wood boiler.
    Timberdog, Slocum, tamarack and 14 others like this.
  4. T.Jeff Veal
    I've burned hickory bark in the stove before. It makes some good heat too...
    Slocum, tamarack, mat60 and 12 others like this.
  5. Warner
    Warner
    I end up with a fair amount of bark on the floor when the wood goes down the slide. It all goes in the stove a little at a time. No sense in lugging it back out.
    Pricey106, Slocum, tamarack and 10 others like this.
  6. sirbuildalot
    sirbuildalot
    Mass
    I burn it as well.
    Pricey106, Slocum, mat60 and 8 others like this.
  7. Backwoods Savage
    The only bark I burn is what is on the log. Or if some falls off when I bring it inside that will go in stove. Also burning bark always seems like there is more ash to contend with.
    Slocum, tamarack, mat60 and 9 others like this.
  8. EODMSgt
    EODMSgt
    White Mountain Region, NH
    Most bark chunks left over from splitting get hauled back into the woods (mostly red oak and red and silver maple). However, I do keep the white birch bark chunks to use as a fire starter. One piece of fatwood and one chunk of white birch bark is pretty much all I need to get the wood stove going.
    Stanley, Pricey106, Slocum and 13 others like this.
  9. buZZsaw BRAD
    If it comes off when im making firewood here its mostly pit wood. My other processing areas its compost. I wont burn black locust bark. If it comes off when split green ill bundle it for future use. Have a couple bundles of sugar maple bark to use from two Summers ago.
    Slocum, tamarack, mat60 and 8 others like this.
  10. TurboDiesel
    Not so much just bark, but I've shoveled kindling into the stove (WS IS) and had the same results. :yes:
    Slocum, mat60, metalcuttr and 7 others like this.
  11. brenndatomu
    If I have some wood that lets go of the bark in big sheets I'll pile it up and burn it a little at a time...either in the firepit, or if there is still some come heating season, then in the furnace...it makes heat too! (or burns better than snowballs, as I've heard said in the past...)
  12. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I never burn bark on purpose. If it’s stuck to the split, so be it. I try to remove as much as I can as I’m processing the the wood and that gets hauled to the dump or left in the field.
    I always thought one of the jobs of tree bark was to help protect it from fire. Seems to generate a lot of ash and take up room in the stacks
  13. The Wood Wolverine
    I burn everything that makes it into the basement. When I throw splits down in the well area, a lot falls off. It all eventually gets shoveled into the stove. If it falls off while splitting, it gets transferred to the burn pile. So no extra effort to bring it in for stove use.
    Pricey106, Biddleman, Slocum and 8 others like this.
  14. TurboDiesel
    Same here. Uglies, unstackables, bark, kindling, i like to burn it all.
    All (free) heat.
  15. RGrant
    RGrant
    Connecticut
    Small yard here, so when I split its usually in or just next to my driveway, and all the bark / shards / smaller chips of wood that fall off, I rake and put in those leaf bags you get at the hardware store. I keep them in my garage and use those as my fire starters / kindling.
    buZZsaw BRAD, Slocum, mat60 and 7 others like this.
  16. Eric Wanderweg
    Here, I'll give you a hand with all that bark
    mat60, tamarack, metalcuttr and 3 others like this.
  17. billb3
    I've read that the bark often has slightly higher BTU content than the wood it is encasing.
    I've only once saved and burned some eastern white pine bark and it does burn OK, just quite a bit of ash.
    These days any bark that falls off outside goes into a compost pile or on one of my compacted trails.
    Any that makes its way in goes in the stove. That's the extent of my bark burning.
    Slocum, mat60, metalcuttr and 4 others like this.
  18. Eric VW
    Happened after the chili I had the other night.
    :fart:
    All parts of a tree make ash… and heat. :salute:
    Skier76, Timberdog, Pricey106 and 8 others like this.
  19. Sean
    Sean
    When we were on the thanksgiving camping trip a few weeks ago we made a tower of doug fir bark in the fire pit. It was hot and lasted forever. Ive burned some of it in the wood stove but also took a third truck full of fir bark to the dump from my recent scrounge. Its good to hear its burning nice and clean. When I burned some in the stove recently I didnt go outside to see if I had clean smoke but I had clean glass. It sounds like its keeping the house warm for you so btus in the stove instead of being discarded sounds like a good win.
    Pricey106, Slocum, mat60 and 7 others like this.
  20. Mag Craft
    Mag Craft
    South East Wyoming
    I never have burned any bark. If there is some that falls off when splitting I throw it in a pile. When the pile gets big enough I haul it to the compost in town.
    Slocum, buZZsaw BRAD, mat60 and 4 others like this.
