Bucking Saws
Discussion in 'Chainsaws and Power Equipment' started by thebierguy, Nov 29, 2020.
  1. thebierguy
    thebierguy
    Hazelhurst, WI
    Ha. I'd imagine there are threads all over about similar topics. I have watched videos and read other threads. Let's start another :)
    Currently been running an Stihl MS270 that I think I have had since 2009 or so. It has been a really good saw, that I don't plan to part with until it implodes: as a back up saw and to do light tree cutting, limbing, etc.
    But, starting a small firewood business, I have been purchasing and plan to purchase truckloads of logs and would like to purchase a bigger saw to speed up the bucking process.
    I had my eyes and heart settled on an MS362, or perhaps a 362C-M. But just like when I was purchasing the tractor, I have now been doing research on the the 70cc class pro-saws (MS462 and 572XP). What I don't like about the 70cc class is that they are about $4-500 more than the 60cc.
    Primari use for the saws would be standing in one spot bucking logs.
    Is the 572XP heavy? I see that it is about 1.3 lb heavier than the MS462 and 2.2 lbs heavier than the MS 362. There is a used 572xp for sale locally that is only 3-4 months old for a reasonable price.
    Will I see noticeable improvement/value of 70cc saw compared to a 60 cc saw?
    Typical log diameter is 12-20". Not typical for logs over 20".
    I'd love any advice anybody might have!
  2. chipsoflyin
    chipsoflyin
    Toledo
    Go for the 572xp and dont look back.
    Screwloose, Husky Man, M2theB and 4 others like this.
  3. tamarack
    tamarack
    paulina oregon
    I've ran both. I have a 462 and a good friend has a 572. The Husqvarna 572 is heavier than the stihl. I really like both, and I'm sure you would be happy with either one. If your only cutting 20 inch wood a 60cc saw would handle it easily.
    Spencer, Screwloose, M2theB and 5 others like this.
  4. huskihl
    huskihl
    What does he want for the used 572?
    70cc is a noticeable jump in power over 60cc. Either would be fine in 20” logs though
    Spencer, Screwloose, tamarack and 6 others like this.
  5. thebierguy
    thebierguy
    Hazelhurst, WI
    $725. 5 tanks of gas apparently.
    Sent from my SM-N960U using Tapatalk
    Spencer, Screwloose, M2theB and 2 others like this.
  6. huskihl
    huskihl
    Fair enough.
    You can get into a new one for $750 with a warranty
    Screwloose, Haftacut, M2theB and 6 others like this.
  7. mike bayerl
    mike bayerl
    For logs under 20" I would use my MS361. It's a lot lighter than my 461. You could get a premium 60 cc saw and have it ported for less than the 70 cc. This is my saw after porting by Scott Kuntz, a.k.a. Tree Monkey. and
    Stlshrk, Spencer, Screwloose and 6 others like this.
  8. thebierguy
    thebierguy
    Hazelhurst, WI
    Oh really? I thought they were closer to $1k. I haven't actually stopped at a dealer though. Good to know.
    Spencer, Screwloose, M2theB and 4 others like this.
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I believe that HL Supply is running a 20% off on Husky saws, but I think it ends tomorrow. Picked up a Husky 55xpg mk2 with 18" bar, but haven't run it yet. I've been running an older Husky 365 special and the newer 562xp. You can do a lot with 60 cc's if you are only running 20" bars.
    Do you know anyone in your area that will let you run some saws to get a feel for them?
  10. JimBear
    JimBear
    Spend the extra cash & get the 70cc saw, put an 8 pin sprocket on & slap a 20” LW bar on it. If you happen to get a load of larger logs then you have the saw to take care of them with out working the smaller saw like a rented mule.
    As far as weight of the Stihl saws I am not sure where you got your weights but my 462 is 2.6#’s heavier than my 261, I would think the difference of the 462/362 would be somewhere in between.
    pic #1 is of my 261 full of fuel & oil
    Pic #2 is of my 462 full of fuel & oil
    C6E2B3ED-6D1F-439E-BD48-AC7837E765A9.jpeg 661FF145-88D5-4B45-9D49-2F40D1DC2A29.jpeg
  11. amateur cutter
    Can't recommend the MS 362, mine just lacks the power I thought it should have. I have an XS 036 pro that will just rip, it'll run with a stock 046. My main bucking saw is a ported 044 by Mastermind & then reworked a bit by huskihl . Either saw will handle the work you describe with speed & comfort. I'd go 60cc class ported if it were me.
    Screwloose, tamarack, M2theB and 3 others like this.
  12. amateur cutter
    If you look at both of JimBear 's pics you'll notice the stickers from the porting guys. A ported saw punches well above it's weight class.
  13. SAWMIKAZE
    SAWMIKAZE
    PGH
    Unless you have a good Husqvarna dealer close I'm not so sure a 572 is a good buy. You need it hooked up for a reset if that situation presents itself.
    20" logs...a 462 is a hell of a firewood saw and doesn't feel much different than a 60cc saw...
  14. thebierguy
    thebierguy
    Hazelhurst, WI
    All of the weights I have been going by are from the manufacturer website literature, powerheads only, I'm assuming dry.
    Ms261<ms270<ms362<ms462<562xp<572xp (as far as weight goes)
  15. thebierguy
    thebierguy
    Hazelhurst, WI
    I appreciate all of the comments. I have both a Husky and Stihl dealer locally, which is nice. I will have to stop in and check out a 462 in person at the Stihl dealer. Or watch for a used one.
  16. The Wood Wolverine
    Run both and judge for yourself. :saw:
    While I agree, porting does add an extra $300 to the price.
    Spencer, Screwloose, Haftacut and 4 others like this.
  17. thebierguy
    thebierguy
    Hazelhurst, WI
    huskihl Can you do your sausage magic on an M-tronic saw or does it have to be straight carb?
    Spencer, Screwloose, M2theB and 3 others like this.
  18. huskihl
    huskihl
    Mtron and autotune both adjust fine by themselves
  19. thebierguy
    thebierguy
    Hazelhurst, WI
    I guess I could have asked a clearer question, with an assumption you port saws. Can you port a M-tronic?
  20. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Kevin can put extra sausage in either.
