Brine
Discussion in 'The Smokehouse' started by Greenstick, Aug 20, 2015.
  1. Greenstick
    Greenstick
    I am just starting to think about doing some brining and smoking. Never brined before and done minimal smoking. Wood any of you care to share your brine recipe/tips and smoke tips. I have a 30 gallon charcoal barrel grill.
    Shawn Curry and wildwest like this.
  2. Elderthewelder
    Elderthewelder
    Washington State
    what are you planning to smoke? i just did some salmon with a dry brine, i do chicken with a wet brine
  3. Greenstick
    Greenstick
    Probably start out with chicken and turkey then move up the food chain.
  4. Elderthewelder
    Elderthewelder
    Washington State
    you dont necessarily have to brine chicken, sometime I do other times I dont.
    when I do brine a chicken I like this recipe, have used it several times and always good results
    Alton Brown Orange Juice Brine
    1 qt vegetable stock, chilled (regular, not low sodium - that's important)
    1/2 cup kosher salt
    1/4 cup dark brown sugar
    1 tsp black peppercorns (I usually use more like 1 tbsp, but I like pepper)
    2 bay leaves
    1 qt. orange juice, chilled
    2 qts. ice water
    Bring 2 cups of the stock, the salt, brown sugar, peppercorns, and bay leaves to a boil. Dissolve the sugar and salt, and cut the fire. Add in the remaining stock, orange juice, and ice water. Once the brine has cooled to 40F or under, add the meat and keep in a cold place (under 40F). Brine for 8-48 hours. This is enough for 2 chickens or 1 turkey
    I went 24 hours on the brine with 2 whole chicken, Cooked at 350 on my GMG for 1 3/4 hours and IT of 165. Came out very nice
  5. Greenstick
    Greenstick
    Ok now I am drooling! Must give that a try. What kind of wood do u smoke with?
    Shawn Curry likes this.
  6. Doug MacIVER
    Doug MacIVER
    Hanover, Ma USA
    try adding cheap imitation maple syrup( real stuff too$$$$, unless you tap your own). adds a great flavor and moistness too turkey and pork loins. even thought a fresh picnic shoulder doesn't need more moisture it does taste good. don't have a smoker, but if I did first thing I would tryout. enjoy. one more, replace h2o with apple juice on some pork, the old apple pork thing.
    WeldrDave, Shawn Curry and Greenstick like this.
  7. Shawn Curry
    Shawn Curry
    Western NY
    I always brine poultry - you get better moisture and flavor, and I think it even makes the cooking process more forgiving - if I overshoot the temp a little, it doesn't get all dried out. I usually do a very basic brine - water, salt, sugar, peppercorn, and onion and garlic slices. For poultry, I'll add some fresh terragon; lemon slices and rosemary work great too.
    Here's a smoked turkey I made for my Memorial Day BBQ. You want to cook poultry at the "normal" oven temperatures - 315-350. Otherwise, if you go "low and slow" at 225, the fat under the skin will not render and turns into the consistency of shoe leather.
  8. Elderthewelder
    Elderthewelder
    Washington State
    thats a nice lookin bird, any pics available after you carved it?
  9. Shawn Curry
    Shawn Curry
    Western NY
    Didn't get any good ones - it went pretty fast... I served it as cold cuts with the lettuce and tomato. There was a little dark meat left when I got the pic. :)
  10. tuneighty
    tuneighty
    South Central PA
    The sky is the limit after you have your salt and water. I had some great reviews after using about 10 bay leaves.
    Greenstick and Shawn Curry like this.
  11. lukem
    1 cup kosher salt
    1 cup brown sugar
    1 gallon of water
    Whatever spices you like
    Greenstick, WeldrDave and Shawn Curry like this.
  12. Mr A
    Mr A
    Problem with making brine is the heating of the brine, then the cooling, takes more time than I would like. It's the salt that does the magic. I just sprinkle kosher salt, wait a few hours, then apply NO SALT dry spice rub. Chicken pieces, an hour or two. Larger cuts, a few hours to a few days depending on timing.
    Greenstick likes this.
  13. WeldrDave
    Thats an excellent one, and I use this alot... I also add crushed garlic to my liking:cool:
    Greenstick and Mr A like this.
  14. lukem
    I do garlic and a fresh minced jalapeƱo.
    Greenstick and WeldrDave like this.
  15. Greenstick
    Greenstick
    Being new to this...I always thought you had to use tenderquick for a brine. Why is it none of above recipes has it, am I mistaken or what advantage is there to not using tq?
  16. lukem
    Tq is for curing....brinse is for flavor and moisture.
    WeldrDave and Greenstick like this.
  17. Doug MacIVER
    Doug MacIVER
    Hanover, Ma USA
    I've skipped the boil and there is no real dif. just give it time to dissolve , heat just quickens the process.
  18. lukem
    I never heat my brine....just tap water.
  19. lukem
    As for wood...apple works great for everything. It is a great starter wood. Some wood will get bitter or burned tasting if you don't know what you are doing but it is hard to mess up with apple.
  20. Greenstick
    Greenstick
    So what is cured vs brined as I have thought they were the same thing?
