Bought a Splitter Today
Discussion in 'Chainsaws and Power Equipment' started by Fanatical1, Mar 18, 2014.
  1. Fanatical1
    Fanatical1
    Went and bought a splitter today. Northstar 32 ton. It was a new "scratch and dent" model. Unused and had some freight damage that scratched the paint on the hydraulic tank which was already touched up so no big deal in my book. There's a few scratches on the engine housing also.
    Honda GX270, 5" cylinder, 16 GPM two stage pump, 18 gallon hydraulic tank, 12" narrow fixed wedge and 3/4 high pressure hoses. $2,100. I'll probably add the four way wedge option. Not the fastest cycle time, but I'm OK with that.
    I'm pretty jacked up about it. Never had a splitter before.
    Hammy, clemsonfor, Wanefree and 21 others like this.
  2. Well Seasoned
    Awesome. Definitely report back(with pics) during processing!:thumbs:
    Fanatical1 likes this.
  3. Stinny
    You're gonna wonder how you got by without it… let us know how sleeping with it in the garage the first night goes… :yes:
    Hammy, Fanatical1, Hedgerow and 3 others like this.
  4. WeldrDave
    Very Nice!....
  5. Fanatical1
    Fanatical1
    Is it that apparent? :drool:
    HoneyFuzz likes this.
  6. Stinny
    No… it's just that we all slept with ours splitters the first night… :drunk::fire:
    Hammy, Gasifier, Fanatical1 and 5 others like this.
  7. FTG-05
    FTG-05
    TN
    HaHaHa!!! That's pretty funny!!!
    Wait, what? You were serious.....?!
    HoneyFuzz and Loon like this.
  8. Certified106
    Certified106
    In The Hills
    Congrats! You will love having one! :thumbs:
    Fanatical1 and HoneyFuzz like this.
  9. Stinny
    Well… yeah…
    Fanatical1, cbake and HoneyFuzz like this.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    SWEEET !!! Congrats :) Definetly report back...been thinking about one of those !
  11. Oliver1655
    Oliver1655
    Central Missouri
    Next out-feed tables, :) then a log lift & your smile will just get bigger! :D
    the GOAT, OhioStihl and HoneyFuzz like this.
  12. Chvymn99
    Cycle time is overrated any way, as long as its not a sloth. Good looking splitter Should be a splittin' machine...:thumbs:
  13. nate
    nate Banned
    Palmer, AK
    Should be fairly quick with a 16gpm pump.
  14. Oliver1655
    Oliver1655
    Central Missouri
    Cycle time of 14 seconds. By the end of the day you will have big pile of splits & a smile on your face! :axe::)
  15. Fanatical1
    Fanatical1
    Thanks guys...
    Had a good nights sleep last night in the garage... :smoke:
    What do you guys about the optional feedout table for a hundred bucks?
  16. MasterMech
    Yes!
    Chvymn99 and HoneyFuzz like this.
  17. Stinny
    "Had a good nights sleep last night in the garage… :smoke:" … photos? Next to the splitter… c'mon.
    Pallet Pete, Chvymn99 and HoneyFuzz like this.
  18. My IS heats my home
    My IS heats my home
    Albany, NH
    Agreed, you will be looking to modify when you get comfortable. Gotta get those big bad boys up there somehow!!
  19. Stinny
    Comfortable = bunk bed attachment
  20. Oliver1655
    Oliver1655
    Central Missouri
    An out-feed table is an awesome addition. I have concerns about the design of the one you are showing. I will list features I like in an out-feed table:
    - Have the table begin before the round meets the wedge to where the round is over the table before splitting. Prevents the round from being pushed into the edge of the table.
    - Have the table long enough it will hold 2 splits end to end. This allows the unloader time to work without the next split hitting the ground.
    - I like to use 3/4" pipe or angle iron with a 1-1/2" gap between them running parallel to the beam for the table. One, it allows debris to fall through the gaps & two it helps the splits to travel in a straight line. This is real helpful if you were to use a conveyor.
    - Keep the table below level of the beam an inch or so. Helps to prevent the splits from binding against the table.
    - Have it flat as it goes out from the beam for 14-16" then if you want you can have the edges angle up. On mine they are just flat.
    For close to the same money, you should be able to have a better one built.
